headwork for 450whp?
Old Oct 14, 2008 | 12:51 PM
irishflame27's Avatar
Default headwork for 450whp?
i am planning on making 450whp or so on my b16 (built) just wondering if a simple reconditioning and 3 angle valve job will be okay, i also will be installing springs and retainers at the same time. what places do you all reccomend for this? i am located in arizona
Old Oct 14, 2008 | 12:54 PM
nsxmatt's Avatar
If your only doing 450whp then no headwork is needed unless your just really wanting to have it done.
Old Oct 14, 2008 | 01:07 PM
Top Ramen's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">If your only doing 450whp then no headwork is needed unless your just really wanting to have it done.</TD></TR></TABLE>
x2.
A valve job is always a good idea on an older head, but no porting, ect. is needed at that power level.
Best of luck with your project.
Old Oct 14, 2008 | 01:34 PM
champLSinteg's Avatar
Default Re: (Top Ramen)
Porting does help but not needed. At that power level, that money can be better spent on lots of other things, unless you do it yourself like I did . I would do the valve job though if its an old head like Top Ramen said.
Old Oct 14, 2008 | 02:47 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">A valve job is always a good idea on an older head, but no porting, ect. is needed at that power level.
Best of luck with your project.</TD></TR></TABLE>
best advice right here, might as well change those valve guide seals also
Old Oct 14, 2008 | 09:50 PM
reaction360's Avatar
Default Re: (blinx9900)
stock port, valve job, supertech springs n retainers. stock cams. 747whp here
get a valve job, springs n retainers n rev that bitch.
Old Oct 14, 2008 | 09:52 PM
blinx9900's Avatar
Default Re: (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">stock port, valve job, supertech springs n retainers. stock cams. 747whp here
get a valve job, springs n retainers n rev that bitch. </TD></TR></TABLE>
wow! which stock cams? mind giving some more info? motor/turbo/boost level?
Old Oct 14, 2008 | 10:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
wow! which stock cams? mind giving some more info? motor/turbo/boost level?</TD></TR></TABLE>
Full gsr motor. GE sleeves. 85mm. Gsr cams. stock ignition. Top mount, S372R turbo. 34psi.
I just put an igntion system in, trying to get some skunk2 pro1's and go back to the dyno for more boost. looking for 850+whp. just as long as the stock tranny holds
Old Oct 15, 2008 | 06:55 AM
THANKS! i really aprreciate all your info!
Old Oct 15, 2008 | 12:48 PM
teefunk01's Avatar
Default Re: (irishflame27)
made 451whp on stock ports
Old Oct 15, 2008 | 02:36 PM
b20vtech's Avatar
Default Re: (teefunk01)
A buddy of mines made 554whp on stock port/ PortFlow 3 angle vj
@16psi
83mm GE sleeved GSR block
custom CP 9:1 pistons
Pauter rods
GSR crank
GT35r
B16a head
ctr cams
supertech springs/retainers
JG Victor X manifold Portmatched
Ericks Racing 72mm TB
vtec dub
Oct 5, 2008 08:31 AM
nexgen91
Feb 21, 2007 08:44 AM
hybrid1990crx
Jun 15, 2006 10:18 AM
tommy.
10
Mar 28, 2006 09:22 AM
wahabum
Mar 9, 2006 08:01 AM
