Headgasket vs. pistons and rods...
Old Jan 12, 2002 | 08:56 PM
AllMotorITR's Avatar
New User
Default Headgasket vs. pistons and rods...
I was just wondering, if I got a turbo kit on my R, could I just use a 9:1 compression headgasket instead of pistons? What are the advantages and disadvantages of both?
Old Jan 12, 2002 | 11:33 PM
HXMan's Avatar
Default Re: Headgasket vs. pistons and rods... (1 FAST R)
I was thinking about a head gasket as well...but these two quotes from Corky Bell's book: "Maximum Boost" have made me wary
(Assuming low comp head gasket installed) Consider "squish volume" sacred and do not tamper. It is possible to err so badly in removing the squish that a resulting 7-to-1 compression ratio may ping worse than a 9-to-1 with proper squish. Clearly then, choices for reducing compression ratio are limited to opening up selected parts of the head side of the chamber, installing a new piston with a dish in the center, or remachining the original piston to create a dish.
Approaches to lowering the compression ratio that do not work are thinner head gaskets and shorter connecting rods.
I advice anyone considering a turbo system, or anyone that already has a turbo on their car to get this book. It explains everything you need to know, simply and effectivly.
[Modified by HXMan, 2:34 AM 1/13/2002]
Old Jan 13, 2002 | 12:41 AM
BlueShadow's Avatar
Default Re: Headgasket vs. pistons and rods... (HXMan)
or in short dont get the headgasket, but get the low comp pistons and rods instead. and remember to get you fuel tuned right.
khaledbuiltEF
Sep 25, 2010 09:35 PM
tremblay
Oct 27, 2009 05:03 PM
94egcoupeturbo88
Dec 9, 2006 01:00 PM
lsvtec
Dec 4, 2001 09:46 AM
