Head Studs/Bolts
Old Feb 9, 2006 | 05:56 AM
Fatty_1775's Avatar
Default Head Studs/Bolts
Whats the difference betweent the two? Do they do the same thing? What do I need to change so the engine can handle the boost? Im tuning and internals are done also. Thanks.
Old Feb 9, 2006 | 08:26 AM
PrecisionH23a's Avatar
Default Re: Head Studs/Bolts (Fatty_1775)
Stock head bolts cannot be reused due to bolt stretch. Go with ARP head studs... they are reuseable as well.
Old Feb 9, 2006 | 08:27 AM
sh!tsWEAK!'s Avatar
Default Re: Head Studs/Bolts (PrecisionH23a)
Stock headstuds will stretch. Get ARP head studs.
Old Feb 9, 2006 | 11:00 AM
tgreaves's Avatar
Default Re: Head Studs/Bolts (TopSecretEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopSecretEg6 &raquo;</TD></TR><TR><TD CLASS="quote">Stock headstuds will stretch. Get ARP head studs. </TD></TR></TABLE>
If you wanna be technical about it, ARP studs stretch also..
Old Feb 9, 2006 | 11:02 AM
Default Re: Head Studs/Bolts (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
If you wanna be technical about it, ARP studs stretch also..</TD></TR></TABLE>
But the difference is that the ARP's use a stud/bolt set-up to compensate for the amount of stretch. The extra 'stretch' is not factored in because it just sits above the actual bolt whereas with the stud it goes deeper into the block.
EFstyle
Nov 2, 2008 11:30 AM
kornerk12
Feb 7, 2007 09:03 PM
eg6cusco10pt
10
Sep 23, 2004 05:39 AM
wade
Jun 22, 2004 08:40 PM
iperez
Feb 11, 2004 07:21 AM
