Head oil galley hex plugs
Old Feb 22, 2007 | 10:23 PM
Muckman's Avatar
Moderator in Chief
Default Head oil galley hex plugs
I recently media blasted my GSR head. In an attempt to clean it thouroughly I needed to remove all oil galley plugs. There are 3 small brass hex plugs that were a bitch to get out. They must have been loctited from the factory as I had to drill all 3 out. So now I need to replace them. Unfortunately its not an OEM replaceable part. Does anybody know where I can get these and what size they are?
Old Feb 22, 2007 | 10:37 PM
RCautoworks's Avatar
Default Re: Head oil galley hex plugs (Muckman)
I have one sitting here I was going to toss in the garbage, well I believe its the same size. I also have two spare blocks in the shop for mock up that I could always pull them off of.
Old Feb 23, 2007 | 05:03 AM
raiden571's Avatar
can u just use a standard npt plug, looks like maybe a 1/4. ud just have to tap it for the new threads
Old Feb 23, 2007 | 06:21 AM
Muckman's Avatar
Moderator in Chief
Default Re: Head oil galley hex plugs (RCautoworks)
Well if you can remove the plugs without destroying them I'll be happy to buy them. However I dont think its easy, all mine stripped. Plus without them your heads will be worthless.
Its def smaller than 1/4" NPT. maybe 1/8" but more likely a metric size. Anybody know?
Old Feb 23, 2007 | 06:41 AM
RudeLude's Avatar
why dont you just drill and tap it for the closest npt size, and get the npt plug to fit it?
Old Feb 23, 2007 | 06:44 AM
HiProfile's Avatar
Default Re: Head oil galley hex plugs (RudeLude)
That would be the easiest solution. I would still recommend going to a place like Fastenal, or whatever fastener place is around you. They can usually find any threaded part, or even make it to order.
Old Feb 23, 2007 | 07:02 AM
IN VTEC's Avatar
I just retapped the three for NPT plugs. You'll need two 1/8" NPT plugs and one 3/8" NPT plug.
Old Feb 23, 2007 | 01:43 PM
I already took one of near the vtec area, thats all I remember. Came out easy with the right tool, and the heads are just "mock" up heads
Old Feb 23, 2007 | 02:00 PM
EJ1 wilcox's Avatar
JB weld??
*runs and hides*
Old Feb 23, 2007 | 04:19 PM
stealthmode62's Avatar
Default Re: Head oil galley hex plugs (EJ1 wilcox)
If you need 1/8 npt plugs, let me know. I've got a bunch I can spare.
Old Feb 23, 2007 | 10:15 PM
uglyasscivic's Avatar
Default Re: Head oil galley hex plugs (stealthmode62)
they are actually a 1/8 british standard pipe thread (1/8 BSP)
http://www.cgenterprises.com/m...t.htm
Old Feb 25, 2007 | 05:05 AM
Muckman's Avatar
Moderator in Chief
Default Re: Head oil galley hex plugs (uglyasscivic)
You sir are the man. Thank you very much.
Old Feb 25, 2007 | 06:51 PM
Turbocivic94's Avatar
I had to remove mine cause it was leaking, it was a bitch. I took them out of a spare head with heating them up.
91 Wagon
Oct 3, 2012 03:56 PM
THEUSED
Mar 30, 2005 02:19 PM
vxnine
Jan 22, 2005 02:08 PM
nyo91
Jun 25, 2004 06:04 AM
civbeater90
Honda Motorcycles
May 2, 2003 09:09 PM
