Head gasket Question ???
For the second time, I blew up my head gasket... the fact is that head lift where the water port are... only at one spot... I think that this is due to a lot of pressure and heat... Can I put 2 OEM gasket one over the other to reduce my compression level a little bit ? Now I am at 9.0 : 1 with JE piston and boost 15 psi ...
And is it goop to applied copper spray before put the gasket on ???
Do you recommand me an other gasket brand ( I use the OEM one with ARP head studs... )
Thank you for the help
Definetly use 2-3 coats of copper spray.
Have you looked into Cometic HP hg's? I prefer them personally. They have a firering in between the layers that offers extra seal around the bore.
thank !!! but the site require something that I dont have...weird ...and I dont know how to do that ..anyway thank and I do a search ...so I will order my Cometic gasket tonight...
new_climber
Honda Civic (2001 - 2005)
Aug 28, 2023 12:11 PM
94gsr
Sep 12, 2002 11:37 AM
