Head Gasket and BORE??
Search did not reveal anything so here it goes...
My gsr block is bored 20 over and i was wondering if i need a special head gasket for that? I will be boosting around 8-10 lbs on a T3/T04E. Any help will be apreciated
20 over is fine for the oem size.
think about it... in the honda service manual they sometimes recommend a slight bore on the cylinders with over sized oem pistons. everything in the book is oem and they dont make an oversized headgasket last time i checked....just to make u feel better
Cool, thanks for the info.
Another question>> i have 10.6:1 JE pistons, should i get 9.0:1 pistons or use a thicker gasket to lower the CR? I will be using the VAFC hack with this also.
Personally I would drop it down via pistons but it's really up to you... I however would NOT change your C/R with a headgasket (leave that up to pistons and pistons alone) but that's also just me... Just my $0.02
SupaFly_Honda
Jun 25, 2009 09:16 AM
Slimm-rw-
Nov 28, 2004 09:45 AM
