having problems with engine temps
Old May 30, 2002 | 04:29 AM
92SiTurbo's Avatar
Default having problems with engine temps
Ok i have a JG pro series block with closed decked in my car. I have all new sensors for the thermostat and a new thermostat too. I also am using a civic Fluidyne radiator. Now the problem i'm having is that the stock tempature gage sometimes goes way above where it should be then falls sometimes very quickly but sometimes comes down very slowly. I do know that the fan is kicking on when the motor starts to get hot and it stays on until it cools it down. I'm only running about 5psi and have about 1200 miles on my new rebuild. Any help would be greatly appreciated.
Old May 30, 2002 | 06:09 AM
rtype11's Avatar
Default Re: having problems with engine temps (92SiTurbo)
could just be very bad tuning, massive ignition retards will do that also.
check that water pump functions normal and that thermostat opens properly and stays open, get a real water temp gauge to know for sure when you hit to high.
Old May 30, 2002 | 05:54 PM
92SiTurbo's Avatar
Default Re: having problems with engine temps (rtype11)
Thanks for the help. I'm going to get a good water temp gauge to monitor my motor.
Emilytcivic
Honda Civic (2006 - 2015)
Nov 22, 2014 04:54 AM
hatchman88
May 30, 2009 05:50 PM
bumthology
11
Dec 11, 2004 11:23 AM
Ruby Civic
Feb 11, 2004 04:37 PM
