has anyone run a 75 shot without retarding the timing?
Old Apr 12, 2006 | 08:28 AM
bootlegtrader's Avatar
Default has anyone run a 75 shot without retarding the timing?
i have pistons, rods, and a wet kit. on the dyno i sprayed a 55 shot at 16 degrees, no problems. and a 75 shot at 14 degrees, no problems. i dont have any "real" engine management or msd to control timing, but i dont like the way the car feels at 14 degrees, na.
has anyone run a 75 shot without retarding the timing, without problems? thanks.
Old Apr 12, 2006 | 09:45 AM
delacampos's Avatar
Default Re: has anyone run a 75 shot without retarding the timing? (bootlegtrader)
a few years ago a ran a 75 shot (NX wet kit) on my sohc daily driver for quite some time on stock timing. never had any problems. just changed the plugs regularly and ran 93 octane. before i sold the car i did a compression test and surprisingly the numbers were great.
Old Apr 12, 2006 | 10:29 AM
Default Re: has anyone run a 75 shot without retarding the timing? (delacampos)
that is encouraging, especially on a sohc. thanks. anyone else?
Old Apr 12, 2006 | 10:57 AM
Kelly.'s Avatar
I've quit using this account
i ran a zex dry 75 shot on a 94 accord coupe.
all i had was i/h/e
i beat the **** out of it for 9 months until it was totaled
motor never had any problems
have fun.
Old Apr 12, 2006 | 06:17 PM
SOHCD16y8's Avatar
I had an 85 shot on a D16y8 back in the day stock everything other then I/e.
Old Apr 12, 2006 | 06:34 PM
Under_Pressure's Avatar
Default Re: (SOHCD16y8)
I had a 75 wet on my h22a i/h/e vafc2. It was tuned for it.
Old Apr 12, 2006 | 09:22 PM
Default Re: (Under_Pressure)
none of you retarded the timing? wow. all the install guides say to retard 4 degrees for that big of a shot. i also have a vafc, tuned with a perfect air/fuel ratio. thanks for the info. i would like to hear if anyone else has anything to say.
Old Apr 12, 2006 | 11:34 PM
integrawhat's Avatar
i ran a 75 shot on my ls with the a 4 degree retard and it ran fine when not being sprayed. maybe your problem is not the timing. i cant find my manual right now but i read the timing on my currently stock 95 gsr at 15 degrees yesterday is this where its supposed to be at stock
Old Apr 12, 2006 | 11:47 PM
2point2's Avatar
back in the day I melted a couple spark plugs with the ZEX 75 shot and no tuning.
What you should do is pay close attention to your bottle pressure (with the help of a bottle warmer) and have the car tuned on the dyno with a wideband. Otherwise you're going to be one of those people who are resposible for giving nitrous a bad name..
My friends are nitrous junkies (on V8s) and their setups are night and day after a tuning session. I've personally seen 40-50hp gains and better a/f ratios! (mid 500whp though)
Old Apr 13, 2006 | 05:59 AM
O i forgot to mention. I used ngk iridium plugs when i sprayed
Old Apr 13, 2006 | 07:26 AM
s2kdre's Avatar
Default Re: has anyone run a 75 shot without retarding the timing? (Under_Pressure)
12 degrees of timing with a 70 shot on my jdm r
Old Apr 13, 2006 | 09:44 AM
Kelly.'s Avatar
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">i ran a zex dry 75 shot on a 94 accord coupe.
all i had was i/h/e
have fun.</TD></TR></TABLE>
i did use a one step colder plug, checked them after each run and changed them after ~ 4-5 runs.
also had a bottle warmer and kept the bottle pressure up
Old Apr 13, 2006 | 03:31 PM
Default Re: (integrawhat,2point2)
i am not having a problem. but there is a very noticeable difference from 16 to 14 degrees. stock timing marks are 14, 16, and 18 degrees. everything is set up right, including plugs, timing, a/f. a dyno with wide band will tell you nothing about knok or pinging. all i was qurious about was timing. thanks though.
Old Apr 16, 2006 | 03:46 AM
speedworks's Avatar
Default Re: (bootlegtrader)
back in 1995 i had a 95 dry shot on a stock ls motor with the timing at full advance on 110 octane. no problem in over 2 years.
XzIpK
May 13, 2007 07:16 PM
JDMIntegraB16
Nov 29, 2005 07:25 PM
Mattmob
Dec 20, 2004 05:54 PM
HotImportNightHonda
Sep 23, 2004 09:43 AM
madhatch
Jun 6, 2003 09:29 AM
