h22 weird stumble
Old Mar 22, 2014 | 06:55 PM
Calebp's Avatar
Default h22 weird stumble
ok its hard to explain but ill do my best i have a fully build h22 on s300 when i go down the road does not matter what gear sometimes the rpms will just drop to zero until i let off the gas then they will go back where they should changed the tps brand new map 4bar no leaks vac wise allso my check engine light is flashing it was solid until i install the new 4bar map only codes i have on hondadata is Iat and idle air control. Also new base map for 4bar and help please let me know dizz is what iv been told idk tho
Old Mar 22, 2014 | 08:33 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: h22 weird stumble
Basemap? if so that is your problem
a basemap is meant to start a car to check for proper operation and to allow for tuning to be done, under no reason is it meant to be driven on...
Old Mar 23, 2014 | 06:05 AM
Calebp's Avatar
ya basemap from phearable.net set up for the car just until i can get to the tuner but would a basemap cause that problem and randomly flashing check engine my air to fuel is perfect so is timing
Old Mar 23, 2014 | 05:38 PM
wantboost's Avatar
Who is Mr Robot?
Nothing on that basemap is perfect.... that's why it's called a basemap.
they sure as hell aren't meant to be used to beat on the motor. don't drive it until you can have it properly tuned
Old Mar 24, 2014 | 03:18 AM
Calebp's Avatar
Do you have any good tuners you recommend ?
hatchback13sec
Nov 13, 2008 12:54 PM
turbogsr18
Engine Management and Tuning
May 18, 2008 08:00 PM
H22A_HB
Dec 25, 2004 01:09 PM
swrdply400mrelay
Jul 2, 2003 09:15 PM
