h22 weakness
Old Mar 3, 2005 | 11:47 AM
deeweezy187's Avatar
Default h22 weakness
what are the weaknesses of the h22 engine and how can i fix them so nothing major can happen when i turbo it. I am lookin to make between 400-500whp.
Old Mar 3, 2005 | 11:52 AM
PM-Performance's Avatar
Default Re: h22 weakness (deeweezy187)
other then the fact of it being a Honda motor?
lol.
I think some parts are harder to find for them then bseries. like manifolds and such. I think the bottoms were pretty stout, but something makes me think I read something about the Rods in the past?
Try a search too, cuz i know i read some chit on here about them plenty of times
Old Mar 3, 2005 | 12:01 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweezy187 &raquo;</TD></TR><TR><TD CLASS="quote">what are the weaknesses of the h22 engine and how can i fix them so nothing major can happen when i turbo it. I am lookin to make between 400-500whp.</TD></TR></TABLE>
The sleeves are not metal: they are a fiber composite that requires a special touch to run with high-psi turbo applications. I would suggest a full-sleeve job if you're planning to make that much power.
Old Mar 3, 2005 | 12:02 PM
LostSolVTEC's Avatar
Default Re: h22 weakness (itr206)
i think it's with the sleeves, that they need to be resleeved to use any type of forged piston. Correct me if i'm wrong
damn someone beat me to it lol
Old Mar 3, 2005 | 12:04 PM
Default Re: h22 weakness (LostSolVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSolVTEC &raquo;</TD></TR><TR><TD CLASS="quote">i think it's with the sleeves, that they need to be resleeved to use any type of forged piston. Correct me if i'm wrong
damn someone beat me to it lol</TD></TR></TABLE>
Thats what it was. I thought there was something with the rods.
Old Mar 3, 2005 | 12:09 PM
RA062424's Avatar
The ringlands are the weakest, they'll go real quick if your not carefull. The block is made of FRM "fiber reinforced material". It's good stuff, strong as **** however it makes it real abrasive to aluminum forged pistons.
So in order for you to really up the boost you'll have to resleeve the block. (But there is a rumor that Mahles new gold coated piston is made so you don't have to resleeve). Noones tried it yet.
Old Mar 3, 2005 | 12:41 PM
Antilag's Avatar
Default Re: h22 weakness (rseaburgh)
Defenitely sleeve the block, the stock block will not tolerate anyboost above 8-9 psi. Save the hassle and get it sleeved, and as for h22 parts, they have plenty of aftermarket parts for them to do your build. Any help just pm me.
Old Mar 3, 2005 | 01:08 PM
b16hybridsol's Avatar
Default Re: h22 weakness (9sech22civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rseaburgh &raquo;</TD></TR><TR><TD CLASS="quote">The ringlands are the weakest, they'll go real quick if your not carefull. The block is made of FRM "fiber reinforced material". It's good stuff, strong as **** however it makes it real abrasive to aluminum forged pistons.
So in order for you to really up the boost you'll have to resleeve the block. (But there is a rumor that Mahles new gold coated piston is made so you don't have to resleeve). Noones tried it yet. </TD></TR></TABLE>
weisco is supposed to have a piston with coated skirts that can run in the frm sleeve also, but i have yet to see proof.
As for the weak points it is the ringlands as stated above. They will go before anything else, and they usually give out around 350ish whp
Old Mar 3, 2005 | 01:41 PM
RA062424's Avatar
Default Re: h22 weakness (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">
As for the weak points it is the ringlands as stated above. They will go before anything else, and they usually give out around 350ish whp</TD></TR></TABLE>
Old Mar 3, 2005 | 01:44 PM
m R g S r's Avatar
Mahle just came out with a solution. . .
Old Mar 3, 2005 | 02:03 PM
Default Re: h22 weakness (m R g S r)
where can i get there pistons
Old Mar 3, 2005 | 02:17 PM
dustin's Avatar
Yeah apparently Mahle makes pistons that work with the h22 fiber sleeves now. But they are really expensive... hehe. Money that could be used towards sleeves and regular pistons.
Old Mar 3, 2005 | 02:23 PM
Default Re: h22 weakness (dustin)
o damn thank u guys for all ya'll help
Old Mar 3, 2005 | 02:24 PM
DOHCtah's Avatar
agreed on a stock bottom its the ringlands that will go first..
the frm-compatible Mahle pistons are advertsied to so but I personally wouldnt wanna be the guinea pig for that price tag.
Old Mar 3, 2005 | 02:58 PM
Antilag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Yeah apparently Mahle makes pistons that work with the h22 fiber sleeves now. But they are really expensive... hehe. Money that could be used towards sleeves and regular pistons.</TD></TR></TABLE>
Well said i feel warm in fuzzy inside having the sleeved block.
theSQad
May 25, 2007 07:39 AM
vietkidracing
Jun 13, 2006 01:37 AM
huge230
Dec 6, 2005 03:46 PM
Hatchorama
11
May 12, 2005 06:58 AM
StraightCivic
Mar 29, 2005 07:38 AM
