H22 Turbo build
Old Aug 11, 2008 | 11:37 AM
alphagroove's Avatar
Default H22 Turbo build
My stock engine died, and I just ordered a JDM H22A ODBI to replace it.
I'm looking at going turbo over the winter.
What should I have done while I'm getting the swap done?
Should I wait till I have everything ordered (pistons, rods, turbo, etc) and get that all done at once.
I'd like to do this in stages, but I'm not sure where to start.
My engine arrives in 3 days, so I don't have much time if I want to get stuff done during the swap.
Old Aug 11, 2008 | 02:12 PM
Scheizty's Avatar
Default Re: H22 Turbo build (alphagroove)
You will want to remove the stock engine while you wait for the JDM one to arrive.
Old Aug 11, 2008 | 02:44 PM
Default Re: H22 Turbo build (Scheizty)
har har, very helpful..
Old Aug 11, 2008 | 02:53 PM
Scheizty's Avatar
You never mentioned that you took the stock one out, so I can't assume it has been done. What car is this coming out of/going into? Is this a civic, a prelude, or what? If it is a prelude, what year, because you may need to consider obd1/obd2 harness and an injector box for peak and hold type injectors.
All that you have said is that you have a car with a broken engine, and a jdm h22 to replace it...
Old Aug 11, 2008 | 05:02 PM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphagroove &raquo;</TD></TR><TR><TD CLASS="quote">Should I wait till I have everything ordered (pistons, rods, turbo, etc) and get that all done at once.</TD></TR></TABLE>
if i were you i'd put the stock motor in, maybe do a manuel tensonier swap.
then when you can get the block sleeved and have all the parts to build the motor, install the turbo and get it tuned in one shot.
In the mean time i suggest a lot of research
Old Aug 11, 2008 | 05:37 PM
Default Re: H22 Turbo build (oranginal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal &raquo;</TD></TR><TR><TD CLASS="quote">
In the mean time i suggest a lot of research </TD></TR></TABLE>
thanks.
its a 2001 prelude.
Ive just ordered the JDM odbi h22a with LSD tranny. Engine comes with all accessories including ECU. I also bought the ODB2 to ODBI wire harness anyway.
the car is sitting at the shop with the broken motor, new one is on-route and should be arriving by friday.
I'll look into the manual tensioner ish, and injector box?
seems there may not be any key things to do just yet, and best do the turbo setup in one shot.
thanks again for the feedback guys.
Old Aug 11, 2008 | 06:30 PM
street_ride14's Avatar
turbo setup in one shot you say ? With those frm sleeves you got on that motor, your ideal turbo install in one shot is not going to be possible. Research the H-platform a little more closely.
Old Aug 12, 2008 | 06:08 AM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">turbo setup in one shot you say ? With those frm sleeves you got on that motor, your ideal turbo install in one shot is not going to be possible. Research the H-platform a little more closely.</TD></TR></TABLE>
just to point out he is referring to how h22's have notorious ringlands that don't take much to crack. and here is the info about the sleeves and piston you will have to know about: https://honda-tech.com/zerothread?id=313407
Old Aug 12, 2008 | 11:32 AM
Default Re: H22 Turbo build (street_ride14)
Ya, exactly. By one should I mean, I get everything done at once, including pistons, sleeves, rods, whatever I need.
I know with the h22 I'll need to upgrade the internals, and plan to.
I was thinking of anything I could be doing when I initially get the new engine before it goes back in.
The only thing I think I'll do is the manual tensioner now, rest will wait once I have it all.
Old Aug 12, 2008 | 04:59 PM
eggie75's Avatar
i don't get it. why not just use the money for the jdm motor to build your "dead" motor.
Old Aug 13, 2008 | 06:55 AM
Default Re: (eggie75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">i don't get it. why not just use the money for the jdm motor to build your "dead" motor. </TD></TR></TABLE>
Because I need a car to get around? This is my daily driver. Only time it's not on the road is during the winter (Jan-March) which is when I plan to do up the turbo build.
Old Aug 13, 2008 | 03:04 PM
JDMisGOOD's Avatar
Default Re: (alphagroove)
We've got a fully built turn key H22 sitting here at the shop we'd sell. Built for 800+ Horsepower!
H22A1 Block Gen3 Sleeves by JG
JE Pistons
Crower Billet Rods
JG Pro Race Cylinder Head Flows 319cfm
JG Cams
Ferrea Stainless Valves
Dual Valve Springs & Titanium retainers
JG Billet Cam Gears
JG Sheet Metal Intake Manifold
BBK 70mm TB
Custom Fuel Rail
Custom Ceramic Coated T4 Turbo Manifold
$8000+ Invested.
Thanks
Jordan
Jordan@maperformance.com
Old Aug 15, 2008 | 03:39 AM
eggie75's Avatar
sorry i must've misunderstood. you said your stock engine died. so... during the time you were waiting for you jdm motor, you could have ordered up your parts and had the block done and saved you the cost of the new motor.
now you have a new motor = $$$
new parts = $$$
dead motor = 0
its ur baby tho, so beaman. dodaritething.
Old Aug 15, 2008 | 11:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">sorry i must've misunderstood. you said your stock engine died. so... during the time you were waiting for you jdm motor, you could have ordered up your parts and had the block done and saved you the cost of the new motor.
new parts = $$$
dead motor = 0
its ur baby tho, so beaman. dodaritething.</TD></TR></TABLE>
yea, im sorta thing I should of went without the car longer and had it done instead now..
but I got the replacement engine in just 5 days from when it died. Another 2 and it'll be back on the road. would of taken alot longer to have the stock block re-done and the parts ordered. and would of cost more too, which I dont have all the funds for yet.
Mo Wilkinson
Sep 2, 2018 05:20 AM
soundFX
Jun 15, 2006 05:27 PM
halcyon
May 13, 2004 01:58 PM
97F22B2
Oct 14, 2002 12:12 PM
hybrid_eg
Jun 11, 2002 04:26 PM
