H22 Turbo Build
I have an H22 that has Golden Ealge Sleeves and was also built by them. The head was done by Portflow. I was thinking about turboing it with low boost nothing over 10psi. What are some of your opinions. Thanks
JE 11.5:1 comp pistons
Eagle rods
REV vavles
Ti retainers
dual valve springs
Stage 2 Skunk 2 cams
s55lph(hp) fuel pump
550cc RC injectors
STR fuel rail
Hondata s300
Stage 4 clutchmaster
Fidanza lightweight flywheel
2.5" custom exhaust
cometic head gasket
all new seals water pump oil pump Greddy timing a balancer belts
H22 to H23 timing tensioner conversion
Eagle rods
REV vavles
Ti retainers
dual valve springs
550cc RC injectors
STR fuel rail
Hondata s300
2.5" custom exhaust
cometic head gasket
Your right, I was just thinking that stock it is 10.6:1 and very week compared to my motor now, and it was able to handle around 8 psi pretty safely and now it is built pretty well and yeah the compression is kinda high, but I was just wondering if anyone else has built a high compression turbo motor. I figure that with high compression and maybe not as much boost it would still be pretty crazy and responsive. and power across the board. Thanks for the input
