H22 standard piston size code?
Old May 3, 2011 | 01:31 AM
pcguy760's Avatar
Default H22 standard piston size code?
Searched and could not find anything about the code... my new block is marked "BBBB" for piston size. Now is this the stock 87mm size?
Old May 3, 2011 | 01:51 AM
aznfreakyguy's Avatar
Default Re: H22 standard piston size code?
both A and B piston sizes were "87mm", A just had tighter clearances than B did, if nothing was done to the block, it should still be 87mm, just use pistons size B and check clearances
DulinDragons
Apr 4, 2009 06:54 AM
demitrix
Honda Civic (2006 - 2015)
Mar 11, 2008 02:22 PM
LearningNewb
Mar 23, 2005 07:08 AM
GreenR
Jan 29, 2003 03:39 AM
