h-t afc hack info
Liam... I just wanted you to know that you RULE!!! I just did the MAP mod tonight, removed the ML and changed my AFC settings to:
1k-4k = -40%
4.5k = -37%
5k = -33%
5.5k-7k =-30%
Transition is absolutley SEAMLESS!!!
Dude, I haven't been this happy with my car's drivability in ages! So far the highest i've taken it is about .57bar on the AFC. Tomorrow I'll cross my fingers and hope I can squeeze .7 bar (10psi) w/o a CEL. Thanks again dude!
Oh and thanks to dbman for starting this whole "AFC hack" train of thought
1k-4k = -40%
4.5k = -37%
5k = -33%
5.5k-7k =-30%
Well I guess I owe it to myself to try hooking it up this way although I still can't quite grasp how its working better... maybe my brain is just shot from a long week at work. I'll try it out this weekend.
Oh and I forgot to mention I was running a JRSC-style TPS relay so as soon as I crossed over into boost it delivered a WOT signal to the ECU to force open-loop operation; that made the whole thing a LOT smoother.
Weeeell, I guess it's time I gave this puppy a shot. I don't know that much about the AFC settings other than the fuel (wide throttle?) and of course VTEC settings. I think mine doesn't let me adjust the narrow throttle settings, do I need to change anything? Basically what I'm asking is this - what is EVERYTHING I have to do to make this thing work. Also, I only have RC 310 injectors, do I need the 400+ injectors for this to function correctly? I'm only running 6 lbs boost but I'm getting ready to move up to 8.
Thats very cool you posted this --
I setup a customer's car like this a few months back -- first i did the two map sensor idea then i went right to the single map and TPS, like the AFC is supposed to run.
The car is a 00 Si and the obd2 kept bitchin at me and throwing codes, so this coming week im supposed to convert it to obd1 (im using a p28 chipped with a b16 program & a 9k rpm revlimit) and i actually plan on putting a greddy black box (voltage limiter) on the car. However, this will not go on the MAP sensor, rather between the AFC and the ECU. This will make it impossible for the afc to add more voltage than the ecu can handle. While this is a good idea in a way becuase it wont throw a code, it might prove to be an issue as the afc will suddenly stop adding fuel, especially when i want it to keep going. The customer is a kid who is very patient which allows me to play with his car, but he doesnt want to spend the money for a hondata. As a result he would rather use what he already has (including an MSD 6BTM) so i figure why not? I work on the car after hours for fun, and he brings the
Dude, I haven't been this happy with my car's drivability in ages! So far the highest i've taken it is about .57bar...
liam
Other then that all you need to do with the afc is set both high and low throttle to your negative values (-40% in my case and whatever you need for your 310cc injectors). And thats it...you hookup the AFC just like you normally would.
liam
Good luck with your customers car i would like to hear how it goes.
liam
OK i need a little help here. So your saying hook up the afc as normal and set the valuves to what you say. Then remove old injectors and get 450s witht he resistor box. and then im good to go? DO i need to remove my boost dependant fuel pressure regulator? This sounds like an awsome mod. Is there anything else i need to do this? or am i missing anything? thanks again oh my car is a 2000si with drag3 kit. thanks again
[Modified by turboex, 3:58 PM 3/2/2002]
If you use the 450's I belive you need the resistor box (if they're peak/hold).
As for 310's, I dunno if you can cut it with 310's. It's really dependent on how much boost you want to run, but with the AFC set to trim like -30% on 310's, I don't think you're gonna deliver enough fuel for 9-10psi of boost without running very lean. Maybe if you added 6:1 FMU to the mix you could get away with it, but not just on injector alone.
This is the VAFC right, not the SAFC?? Or does it not matter?? Thanks for answering my stupid ??????'s
liam
Well unless you want to change the VTEC engagement then youshould probably go with the S-AFC. It's supposed to be more configurable. I don't know how, but it does cost more,LOL!
Would this work for someone with a non turbo application, but has DSM injectors waiting to be put it. My car already has a resistor box so that would be easy to do..
Also is there any way of getting around a speed limiter with the APEXI VAFC?? And why is the fields unit able to do it?? That would be a great help if you guys could figure out that one for me.
Yes, your application would work also. You'd need to adjust fuel delivery as usual with your SFC.
The FIELD unit removes the speed limiter present on Japanese, er, JDM ECUs. ECUs from US market cars have only the rev-limiter, no speed limiter.
Thanks man. Which one would you say is better for a FI car. I was thinking the Vafc, but Im not really too informed....
liam
Are you sure about that?? I always thought they were identical except the S-AFC didn't have the VTEC cross over feature (and corresponding dual fuel map's for Lo-cam and Hi-cam).
liam
