Which guages??
Old Jun 7, 2004 | 09:44 PM
B00ST2nR's Avatar
Default Which gauges??
Which gauges are needed the most? I'll most likely be getting a Full Pillar Tripple Pod once I boost my GSR. I'm thinkin:
1. Boost Gauge
2. EGT Gauge
3. Oil Pressure Gauge
There's also Air/Fuel Ratio Gauge, Oil Temp Gauge, Fuel Pressure Gauge, Water Temp Gauge, etc.
Which guages are the most important to have?
Old Jun 7, 2004 | 09:50 PM
aw1234dude's Avatar
Default Re: Which gauges?? (B00ST2nR)
1)clock
2)flashy no good air/fuel
3)volts
syke
The three you picked sound good I might also think about a water temp one if you have an extra spot but the three you listed are higher priority then that one.
Old Jun 7, 2004 | 10:22 PM
aznballer's Avatar
wide band o2
boost
egt
Old Jun 8, 2004 | 06:07 AM
White Smoke's Avatar
i my honda
Global Mod
Ya the ones you picked are best. This has been coverd before about 297 times
I personaly say get the A/F as well and hook it up to an inovative or PLX wideband and hook the gauge to the simulated narrowband output
Just my .02$
Thank You And Have A Wonderful Day
Old Jun 8, 2004 | 06:16 AM
Muckman's Avatar
Moderator in Chief
https://honda-tech.com/zerothread?id=748644
Old Jun 8, 2004 | 07:03 AM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00ST2nR &raquo;</TD></TR><TR><TD CLASS="quote">
1. Boost Gauge
2. EGT Gauge
Old Jun 8, 2004 | 07:07 AM
DaX's Avatar
DaX
Loved
Community Favorite
In this order:
Gas Level
Tachometer
Speedometer
boosted.CRX
31
Aug 18, 2006 04:05 AM
Ignitecivic
Feb 25, 2005 08:18 AM
RCautoworks
30
May 9, 2003 06:42 PM
