GT3767S Information
Old Jun 12, 2005 | 04:05 PM
alpha's Avatar
Default GT3767S Information
Has anyone here tuned or have a Honda with a T4 GT3767S? If so could you post some information. Dyno sheets. Boost pressure throughout RPM range. Motor. Anything else you think might be useful. Thanks
Old Jun 12, 2005 | 04:27 PM
Justin Olson's Avatar
Default Re: GT3767S Information (0x64)
One fab ran one on there stock block h22 at over 500whp.
Regards,
Justin
Modified by Justin Olson at 6:25 PM 6/12/2005
Old Jun 12, 2005 | 04:29 PM
alpha's Avatar
Default Re: GT3767S Information (Justin Olson)
I forgot Matt was running a T4 GT3767S. Matt, if you see this if you could please post up, PM me or even call me with some information I would appreciate it. Anyone else as well
Old Jun 12, 2005 | 05:48 PM
alpha's Avatar
I heard people like pictures.
Anyone have any datalogs of this turbocharger on a Honda?
Old Jun 12, 2005 | 06:41 PM
mrbsponge's Avatar
alpha if thats YOUR turbo................I F'ing hate you for life!
Old Jun 12, 2005 | 08:16 PM
This One's Avatar
Default Re: (mrbsponge)
Hey, yea We have been using alot of them lately.
If you want one, i have one in stock for you.
I have one on my car, Im building another car thats indentical with one.
We were using one on the EVO, Fast-turbo stan was on one as well.
I made 536whp and 400 ft lbs of tq before my clutch went out on 27 lbs on 11 degrees of timing.
Our Recent tune, the clutch let go at about 500 whp.
Im fairly confident it would have made a good 550ish.. We were on 23lbs that time around too..
I dont have any current Graphs for that though.
Stan made 680whp I believe on a t3/t4 version.
I dont see any reason why it wont make 700 whp on a full t4 version.
Old Jun 14, 2005 | 07:45 AM
BoostedCivicSedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">alpha if thats YOUR turbo................I F'ing hate you for life!</TD></TR></TABLE>
Not his, but someone else local
Lets bring this one back because Im curious to see how this little snail performs...
Old Jun 14, 2005 | 09:50 AM
Default Re: (BoostedCivicSedan)
Forced performance sells the gt3767S under the name FP3575. A lot of the DSM guys really like this turbo.
http://linux.forcedperformance...P3575
Regards,
Justin
Also, some links to dsm threads about it:
http://www.dsmtuners.com/forum...age=2
also, the 678whp honda:
http://www.tunerzine.com/artic....html
Modified by Justin Olson at 11:16 AM 6/14/2005
Old Jun 14, 2005 | 12:03 PM
99_GS-T's Avatar
The FP3575 uses a T350 turbine wheel and not a GT37 84-trim wheel.
Old Jul 2, 2005 | 12:27 AM
alpha's Avatar
Update: Full boost (15lbs) by 5,800RPM on the old calibration. Retuned most of partial throttle tonight. Going to finish street tuning partial throttle and boost on the way to Daytona Beach today. I will post some datalogs for anyone interested in this turbocharger when I get back into town Sunday night. In a week or two I will retune for a small shot of N20 to help with the lag.
Old Jul 4, 2005 | 08:00 PM
alpha's Avatar
I got partial throttle done yesterday and went out yesterday night to street tune for boost. Get everything dialed-in good and we goto make another pass. Fourth gear from 3,500RPM to fifth gear. I forget what RPM it happened in fifth. I will have to look at the datalogs. Boost started falling off and the car stopped pulling. We pulled over to the side of the road and had the car towed back. I worked on the car today to find out what was/is wrong. The main bearings failed, the oil pump failed and the oil pump gear failed. The head, cylinder walls, pistons and rods are ok The GT3767S felt great at 14.1lbs Too bad we didn't get it to the dyno. I will post the datalogs and we will get it to the dyno in a couple weeks.
Old Jul 4, 2005 | 08:11 PM
D@nnY's Avatar
are you runnign a light wieght crank pulley and fly wheel?
Old Jul 4, 2005 | 08:13 PM
alpha's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">are you runnign a light wieght crank pulley and fly wheel?</TD></TR></TABLE>
OEM crank pulley and fly wheel.
Old Jul 4, 2005 | 08:18 PM
Battle Mike's Avatar
damn, that's a big turbo
Old Jul 4, 2005 | 08:47 PM
Default Re: GT3767S Information (02SilverSiHB)
So are you running the t4 .68 a/r gt3767s? Also, what is your motor setup?
Regards,
Justin
Old Jul 4, 2005 | 11:02 PM
Flamenco-T's Avatar
I had the T3 inlet on my GT3767, we Jason St00pid made over 700 whp and 520 ft/lb of torque on that turbo. So the T4 will nto be a problem.
As a matter of fact, jason had done a lot of GT3767 and he had great experience tuning it.
stan
Old Jul 28, 2005 | 05:24 PM
xsi-t's Avatar
so this turbo should kick *** then huh??
Old Jul 30, 2005 | 09:52 PM
Flamenco-T's Avatar
Default Re: (xsi-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t &raquo;</TD></TR><TR><TD CLASS="quote">so this turbo should kick *** then huh??</TD></TR></TABLE>
Yes, we have sold quite a few of these and everyone have been very happy
stan
Old Aug 1, 2005 | 02:43 PM
alpha's Avatar
Default Re: (Flamenco-T)
Stan, I am going to dub this turbocharger the oil pump killer
The new engine is being built.
Old Aug 1, 2005 | 03:18 PM
SFWDcoupe's Avatar
Default Re: (0x64)
So this is like smaller than a GT40 but bigger than a 35 right?
Old Aug 1, 2005 | 03:31 PM
alpha's Avatar
Default Re: (SFWDcoupe)
Here are the turbine specifications, I assume you know the compressor specifications for each, for each.
* GT3767 Turbine
- Exducer - 66.4mm
- Inducer - 72.5mm
- 84 Trim
* GT40 Turbine
- Exducer - 65.7mm/70.5mm
- Inducer 77mm/77mm
- 73/84 Trim
Old Aug 7, 2005 | 10:00 AM
xsi-t's Avatar
i miss my oil pump
iluvmyda
Aug 31, 2008 09:33 PM
andwutgsr
Apr 20, 2004 07:56 PM
RedStarGsr
Mar 9, 2004 02:29 PM
graphic
Jan 8, 2004 04:23 PM
BeerMoon
Jun 9, 2002 06:01 PM
