GT35R ls/vtec progress thread
Old Nov 28, 2010 | 05:24 AM
rwlsvtec_03's Avatar
Icon7 GT35R ls/vtec progress thread
New to Honda-tech!
Just finished re-building my head (p72-2) with gsr intake valve springs on both intake and exhaust side with 3 angled gsr valves and stock gsr cams.
Just to show you what I'm working with..
About 3 months ago, now has lump in hood to clear turbo.
Quarter panel replacement, antenna shave and full paint (roughly 3 years ago)
Had bottom end built with stock sleeve and bore (1 year ago)
Wiseco pistons 8.7:1 pistons, Eagle H-Beam rods, Eagle 4340 crank.
basically it's current state.. (p72-1 head) about 2 months ago before i had to pull head off due to head gasket failure caused by letting somebody else install. Also in picture exhaust welds werent done either (obviously).
Old Nov 28, 2010 | 01:48 PM
anavrin's Avatar
Default Re: GT35R ls/vtec progress thread
looking good what power are you hopping to get out of it? what tranny u running?
Old Nov 28, 2010 | 02:16 PM
team_ibR's Avatar
nice, very similair setup that I have.
how much power u making and what gas u using? any track times yet?
Old Nov 29, 2010 | 02:31 AM
Post Re: GT35R ls/vtec progress thread
Roughly between 450-515whp. I really don't want to stress those sleeves.
Transmission is out of my '96 GSR. It's solid I just don't know how those original syncros are going to hold. Has Comp Stg.4 clutch/500hp axles.
No power yet. Litteraly Just got the car running again 3 days ago.
Thanks to a headgasket leak and over tightened cam shaft due to letting somebody else do my install.. This time I did it, no leaks, just works.
Plan on only running 93 octane but I would like to have methanol injection come spring time when I get a real tune. (winter in NY)
friend from Texas is coming up to help me work out little kinks and stuff along with a street tune so I can actually Do a break in before we get salt flying.
Motor only has about a half mile on it.
Old Nov 29, 2010 | 03:37 PM
newtype_33's Avatar
nice!
Old Nov 29, 2010 | 09:06 PM
dcmatt's Avatar
Looks like a nic setup. Can't wait to see the nums.
Old Nov 29, 2010 | 10:09 PM
Hondaruss's Avatar
Nice setup. But Kinda concerned is that rubber hose used for fuel feed line and hose clamps? I hope thats not permanent.
Old Dec 1, 2010 | 03:13 AM
ehh. never had a problem running rubber lines before except for way back when I had an FMU. I'd like stainless but I can't really afford now. It's all fuel line and high pressure clamps..
Old Dec 1, 2010 | 05:40 AM
J35monster's Avatar
What topmount is that? Nice build!
Old Dec 4, 2010 | 04:18 AM
honestly.. top mount is obx. equal length and 3 year warranty.
It's nice except for flange.
Old Dec 4, 2010 | 11:20 AM
J35monster's Avatar
Ya it looks like it's a t4 flange and your gt35r is a t3...
Old Dec 5, 2010 | 10:31 AM
Has bolt holes for both t3 and t4..
Old Dec 5, 2010 | 06:55 PM
turbodrx7's Avatar
Good looking setup
Old Dec 5, 2010 | 08:27 PM
93egSLEEPER's Avatar
Holy low compression batman. Nice looking build but which such a low CR? 9.5:1 would have been safe and gotten you a bit better performance IMO
Old Dec 11, 2010 | 04:05 AM
Yeah it is pretty low I'm not worried.
Only thing I have to figure out now is why my wideband isnt reading..
Old Dec 11, 2010 | 07:51 AM
dcmatt's Avatar
Doesn't the vtec head raise compression some aslo?
Old Dec 11, 2010 | 12:05 PM
Slightly depending on how many times this head has been plained.
Old Dec 11, 2010 | 01:33 PM
pantherballhp's Avatar
in for updates. i'm doing a boosted ls/vtec setup. just a question on that flange for the turbo, does it bolt down to the existing t4 setup? i'm going with a t4 manifold for future turbo upgrade but i'm going to be running a smaller turbo on the stock block so i was wandering if that flange just bolts down and u don't have to weld it.
Old Dec 11, 2010 | 01:57 PM
Everything bolts. The flange simply has extra holes to fit t3 also.
Old Dec 11, 2010 | 01:58 PM
NYCE92M3's Avatar
nice bro, perfect set up
Old Dec 12, 2010 | 02:30 AM
thanks man, but It's far from perfect.
Valves are making noise.. (never adjusted) So I'm waiting on Christmas to bring me my b series adjustment set from Honda. Really didn't want to do timing again.
Old Dec 12, 2010 | 07:05 PM
alright that's awesome. just gonna run a t3 turbo on my stock motor and up it to a t4 once the built motor goes in. Thanks for the info. was looking for this and luckily found someone using exactly what i was looking for.
Old Dec 25, 2010 | 05:55 AM
Christmas is a wonderful thing.. AEM Uego Wideband & Hondata 4Bar map sensor.
Have to test and pull out old wideband and if fixed I can have one for my '00 Si.
Matching Energy Suspension Master kit for the '00 on the way. Thinking about taking car up to Innovative for them to finish up..
Old Dec 26, 2010 | 07:23 PM
tdotciviclove's Avatar
nice build
Old Jan 8, 2011 | 05:22 AM
Icon7 Re: GT35R ls/vtec progress thread
Originally Posted by tdotciviclove
nice build
thanks.
Hoping for some drivable weather soon but its all snow up here.
Just got my sparco harnesses and am waiting for full front black carpet and a B&R fitting catch can return back kit. probably going to put on the road with in the next month so I can drive it whenever I get a chance (like up to innovative tuning). Still haven't adjusted valves either..
