GT30 vs. SC61
Old Apr 26, 2003 | 06:56 AM
int3gra's Avatar
Default GT30 vs. SC61
Did the GT30 go out of style when precision came into the picture. I haven't read anything about the GT30 lately. Vaportrail and Cheapturbodotcom were the ones selling these.
Is it even wise to compare these two? What are the differences?
Old Apr 26, 2003 | 07:33 AM
SiRkid's Avatar
Default Re: GT30 vs. SC61 (int3gra)
gt30 ownz it
Old Apr 26, 2003 | 07:34 AM
b18bturbo's Avatar
Default Re: GT30 vs. SC61 (SiRkid)
talked to harry at preicsion he also thinks the GT sereis will own the SC due to faster spool time etc.
There is new line coming soon to replace there sc50 that will be ball bearing and will be competiviely price and spool almost 1200 rpm early. major difference.
Old Apr 26, 2003 | 09:12 AM
t04s's Avatar
Default Re: GT30 vs. SC61 (b18bturbo)
I don't know for sure but it seems the sc61 is essentially a non ball bearing gt35r .The compressor wheel in the sc61 is a gt 40 family wheel but is actually used in thr gt3040 600 which is in the 35r.
Old Apr 26, 2003 | 09:29 AM
DIRep972's Avatar
Smarter than you
Default Re: GT30 vs. SC61 (t04s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04s &raquo;</TD></TR><TR><TD CLASS="quote">I don't know for sure but it seems the sc61 is essentially a non ball bearing gt35r .The compressor wheel in the sc61 is a gt 40 family wheel but is actually used in thr gt3040 600 which is in the 35r. </TD></TR></TABLE>
yup. SC61 is a non-ball bearing GT35R, or GT3040. Its the Largest of the GT30 series turbos. The SC61 uses the GT40 compressor wheel in precision housings w/ precision exhaust sides at a much more affordable price then the GT35R. You basically get the same flow but with slower spool up.
As for now there are no precision alternatives for the smaller series of GT30's like the GT3035 (56 trim) and standard GT30 (52 trim) but I would like to see some in the future.
Old Apr 26, 2003 | 09:45 AM
int3gra's Avatar
Default Re: GT30 vs. SC61 (IRepD)
is a sc61 with ball bearing option cheaper than the GT30?
I really like what I hear about the GT30 and am really considering it. Like VaporTrail said, gotta have best of the fleet that is good for you application.
Old Apr 26, 2003 | 09:52 AM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra &raquo;</TD></TR><TR><TD CLASS="quote">is a sc61 with ball bearing option cheaper than the GT30?
yes, but you still dont get the exhaust side that you would get in the GT35R. ball bearing isn't the only reason the GT35R spools faster, garret made advances in the exhaust wheel and the housing for quicker spool and better flow as well. But that is why it is so expensive. I think it retails for 1800. Just remember the GT35R(GT3040) is the only of the GT30 series turbos that can flow as much air as a SC61. The GT3030 and GT3035 are smaller.
Old Apr 26, 2003 | 10:20 AM
SiRkid's Avatar
how many lbs/min does the sc61 flow? 60 or so?
Old Apr 26, 2003 | 10:29 AM
int3gra's Avatar
the GT35R is too much for what I want. GT30 with .63 is more what i'm leaning towards.
Old Apr 26, 2003 | 01:21 PM
LEON's Avatar
... how soon is soon? I'ld like to get one of these new ballbearing Precision turbos, but cant wait much longer than a month or so.
Old Apr 26, 2003 | 02:42 PM
slowsi00's Avatar
sc61
Old Apr 26, 2003 | 02:45 PM
b18bturbo's Avatar
Default Re: GT30 vs. SC61 (LEON)
per harry you are looking at over 4months or so<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LEON &raquo;</TD></TR><TR><TD CLASS="quote">... how soon is soon? I'ld like to get one of these new ballbearing Precision turbos, but cant wait much longer than a month or so.</TD></TR></TABLE>
Old Apr 26, 2003 | 04:30 PM
LEON's Avatar
What will be the differences between the Garrett GT30 and the new Precision ball bearing turbos?
Old Apr 27, 2003 | 11:40 AM
rca90gsx's Avatar
Just to clarify, the GT3040 is NOT the same as the GT35R the turbine on the 35r is much larger than that used in the 3040. I definitely know, cause i've owned both turbos in the last 6 months.
Richie
Old Apr 27, 2003 | 01:04 PM
DIRep972's Avatar
Smarter than you
Default Re: GT30 vs. SC61 (rca90gsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rca90gsx &raquo;</TD></TR><TR><TD CLASS="quote">Just to clarify, the GT3040 is NOT the same as the GT35R the turbine on the 35r is much larger than that used in the 3040. I definitely know, cause i've owned both turbos in the last 6 months.
Richie</TD></TR></TABLE>
they do use the same compressor and wheel though correct?
Old Apr 27, 2003 | 01:13 PM
Arturbo's Avatar
Better than steak
25 Year Member
I think the GT3040 comes with a 2.62" inducer/ 3.198" exducer compressor, but the SC61 aka GT35R or GT40(so many names, I know) compressor has a 2.41" inducer/3.22" exducer.
Old Apr 27, 2003 | 01:18 PM
SiRkid's Avatar
Default Re: GT30 vs. SC61 (Arturbo)
hks gt3040 is AN HKS thing i beleive while garret has gt30, gt35 etc.
Old Apr 27, 2003 | 02:10 PM
t04s's Avatar
just to clarify the gt3040 600 is a gt35r.
Old Apr 27, 2003 | 04:25 PM
rca90gsx's Avatar
They both share the same compressor wheel, but the 3040 uses the 2.16/2.36 turbine wheel vs. the 35R's 2.45/2.68" turbine wheel. That is really the only difference. Both use the 2.41/3.22 compressor wheel. Most 3040's i've seen have the To4E compressor cover, where the majority of the 35R's have the T04S or T04R compressor cover..... Just preference I guess.....
Richie
Old Apr 29, 2003 | 09:35 AM
int3gra's Avatar
which one is better according to this page: 0.63 a/r
http://www.turbofast.com.au/GTseries.html
705867-0001
or
714569-0003
are these universal Garrett part numbers, need to tell my dad to order me one.
Old Apr 29, 2003 | 01:16 PM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra &raquo;</TD></TR><TR><TD CLASS="quote">which one is better according to this page: 0.63 a/r
705867-0001
or
714569-0003
are these universal Garrett part numbers, need to tell my dad to order me one.</TD></TR></TABLE>
"GT30 <U>714569-0003</U> 700177-0018 0.70 52 TO4S 2.17/3.00 50lb/min 0.63 84"
"GT30 <U>705867-0001</U> 700177-0015 0.70 56 TO4S 2.25/3.00 55lb/min 0.63 84"
which trim wheel do u want? isn't this going on an LS? I would go w/ the smaller 52 trim 2.17/3.00 wheel that flows 50lb/min. thats pretty much perfect for an LS
Old Apr 29, 2003 | 02:40 PM
BLKCRX's Avatar
what are you guys doin with the problem that the GT turbo's BB's are both water and oil cooled ?? have ya though about where / what your goin to do to get the water supply to and from the turbo ??
Regards James
Old Apr 29, 2003 | 02:45 PM
SiRkid's Avatar
Default Re: GT30 vs. SC61 (BLKCRX)
problem???????
its not a prob.. lots of turbos come this way including "regular" t3/t4's.
just get it off the throttle body!
56 trim ownz
Old Apr 29, 2003 | 06:06 PM
BLKCRX's Avatar
sweeet so u jsut tap the water lines.. and then feed to back to them also ? yeah
maybe ill go BB also ! GT35 here i come.. maybe...
Regards James
Old Apr 29, 2003 | 07:10 PM
SiRkid's Avatar
you do you know that lots of t3/t4's come water cooled?
but yeah, just tap into the throttle line..easiest thign to do.
