GSR will not idle
Old Sep 23, 2008 | 08:47 PM
b20vcrxsir's Avatar
Default GSR will not idle
I have a 1999 Honda Civic DX Hatch. It has a built GSR Motor. The car has been running fine for a long time. Recently I went to turn it on and it started but will not idle on its own. If i let go of the gas it will just die. What could cause this?
Old Sep 23, 2008 | 09:49 PM
mtber's Avatar
Default Re: GSR will not idle (b20vcrxsir)
Too many things to list.
Start by telling us what engine management the car is on, what map sensor & if the car is throwing any codes (check engine light).
Old Sep 25, 2008 | 12:27 AM
b20vcrxsir's Avatar
Default Re: GSR will not idle (mtber)
I have Hondata s300, omni power 4 bar map senser, and the car is not throeing any codes
Old Sep 25, 2008 | 02:50 AM
2point2's Avatar
you can start by using the search feature and searching for threads on "IAC" and "LOW IDLE" etc..
It's much easier to help someone if they've tried a few things first.
When you get the car running with the throttle is it smooth and running good?
spintboy
Jan 31, 2008 08:06 PM
CHK4TIX
Jan 27, 2007 05:24 PM
streetlvlhatch
Mar 30, 2004 05:08 PM
CharmCity
10
Nov 2, 2003 03:53 PM
