GSR VS. SI turbo?
Old Sep 22, 2004 | 04:54 PM
caliLS's Avatar
Default GSR VS. SI turbo?
Im deciding between a 94 and up gsr or a 99 si. The car will be turbo, I just cant decide which car to get. Im also working with a budget of 11000 dollars. thanks for any help
Old Sep 22, 2004 | 05:05 PM
AznInvasion's Avatar
Default Re: GSR VS. SI turbo? (caliLS)
gsr
Old Sep 22, 2004 | 05:38 PM
el arbi's Avatar
Default Re: GSR VS. SI turbo? (AznInvasion)
GSR should be faster, but it all depends on what car you want. The 1.8 from the gsr is going to work much better stock for stock against the 1.6.
Old Sep 22, 2004 | 05:56 PM
h22acivicman's Avatar
Keep the Turbo Civic's Going!!!!! But the GSR Would Be NIce too I'm a Honda Man.... But Even though there the same lol
Old Sep 22, 2004 | 06:04 PM
2SlowDC's Avatar
u can only go so far on a 1.6ltr
Old Sep 22, 2004 | 06:15 PM
Boostage's Avatar
Default Re: (lsVtec...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsVtec... &raquo;</TD></TR><TR><TD CLASS="quote">u can only go so far on a 1.6ltr</TD></TR></TABLE>
um.. yeah. both motors can make more power than you can use on a street car
I bet $10,000 you are no where near the limits of your 1.8
Old Sep 22, 2004 | 06:20 PM
2SlowDC's Avatar
Default Re: (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">
I bet $10,000 you are no where near the limits of your 1.8</TD></TR></TABLE>
more power for what price? im just simply stating that a 1.8 ltr powerplant would be a better choice.
Old Sep 22, 2004 | 06:23 PM
TheAntiEndz0r's Avatar
like boostage said, more then likely this guy will not be even close to maxxing out either motor...but i think both cars are ghey. eg and that gen civics are the best!
Old Sep 22, 2004 | 06:24 PM
Boostage's Avatar
more power for what price? im just simply stating that a 1.8 ltr powerplant would be a better choice.</TD></TR></TABLE>
for what price? there parts cost the same for both motors. the b16 may or may not need to run more boost to make the same power. either way, u dont have an advantage with a b18. in a street car when fwd's lack of traction owns you.
its like lets spend 1k more for a b18c because theoretically that 20% increase in displacement will be worth it when your trying to build a 700hp daily driver as opposed to 690hp [/loads of sarcasm]
Old Sep 22, 2004 | 06:29 PM
2SlowDC's Avatar
for what price? there parts cost the same for both motors. the b16 may or may not need to run more boost to make the same power. either way, u dont have an advantage with a b18. in a street car when fwd's lack of traction owns you.</TD></TR></TABLE>
im just curious, but which one would u choose considering that they may be around the same price range depending on what year the gsr?
bigger bores prove to have more low end out of the box.
Old Sep 22, 2004 | 06:32 PM
he's got a super duper fast b16. i've seen it in person.
Old Sep 22, 2004 | 06:36 PM
Boostage's Avatar
bigger bores prove to have more low end out of the box.</TD></TR></TABLE>
b16's and b18's have the same bore its the stroke thats longer on a b18c. as for your question I would chose either. I dont prefer one over the other for my goals. which is to be a really fast street car. best tir eI can get for a daily driver are BFG drag radials, and I have a big enough turbo and fuel system to light those up on either motor.
people need to stop acting like the 10mm difference in stroke of both motors is night and day like the difference between a small block and big block chevy. .2 litres OMG!!
Old Sep 22, 2004 | 06:40 PM
EM1 MIKE's Avatar
Oh really?
Old Sep 22, 2004 | 07:00 PM
2SlowDC's Avatar
ok u know what, delete my first post i take it back. its really a personal preference toward teh direction u want to choose w/ ure engine. as far as forced induction goes, they are both potent engines. im not a hater on b16s because id rather have a b16 turbo over my ls turbo. but MY preference, im sure u can see why i sed the 1.8 gsr turbo would be my choice over the 1.6 b16a turbo
Old Sep 22, 2004 | 07:04 PM
caliLS's Avatar
Default Re: (Endz0r)
how much should I pay for an 99 Si?
Old Sep 22, 2004 | 07:10 PM
EM1 MIKE's Avatar
Default Re: (caliLS)
I got one in 01 for $18,000 from the dealer
and one for $14,000 two years ago from a private party.
I'm sure you can find one for $11,000 nowadays, search autotrader.
Old Sep 22, 2004 | 08:18 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">people need to stop acting like the 10mm difference in stroke of both motors is night and day like the difference between a small block and big block chevy. .2 litres OMG!!</TD></TR></TABLE>
Make no mistake, 10mm worth of stroke makes PLEANTY of difference when you're talking about a measly 1.6L worth of displacement.
Drive a larger turbo B16 then a larger turbo B18, period.
Old Sep 22, 2004 | 08:57 PM
Accord2NR's Avatar
i say GSR because they are sexy, but so are the Si's but the gsr should be faster
Old Sep 22, 2004 | 10:25 PM
donkiman's Avatar
or you could put the gsr motor and turbo in the si...
Old Sep 22, 2004 | 10:41 PM
honda9369's Avatar
Default Re: GSR VS. SI turbo? (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">or you could put the gsr motor and turbo in the si...</TD></TR></TABLE> cha-ching
Old Sep 22, 2004 | 10:43 PM
EM1 MIKE's Avatar
Also an option.
Old Sep 22, 2004 | 10:58 PM
SiRkid's Avatar
Default Re: (VTC_CiViC)
ive driven both..not the HUGE difference that people like to make it out to be. is there a diff? yes but its not earth shattering, like your jumping into a v8 powered car or something
i agree with boostage.
in your case I would do WHATEVER the cheapest route is!(cheapest car)
so most likely the gsr.
at the end of the day it really doesnt make much difference.
you can go just as fast in one as you can in the other!
Old Sep 22, 2004 | 11:07 PM
B00ST2nR's Avatar
Default Re: (SiRkid)
Turbo GS-R &gt; Turbo Si
Old Sep 23, 2004 | 08:49 AM
EM1 MIKE's Avatar
Here's an Si for sale. Don't know if it's in your area or not but expect to pay around this price for a used Si, depending on mileage.
https://honda-tech.com/zerothread?id=1000051
Heres another for around the same price:
https://honda-tech.com/zerothread?id=966452
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRKid &raquo;</TD></TR><TR><TD CLASS="quote"> ive driven both..not the HUGE difference that people like to make it out to be. is there a diff? yes but its not earth shattering, like your jumping into a v8 powered car or something </TD></TR></TABLE>
Exactly. There is a slight noticable difference but not by much.
Modified by EM1 MIKE at 9:59 AM 9/23/2004
GsrIntegra789
Jul 19, 2007 10:22 AM
My_red_ek
Feb 9, 2006 01:52 PM
Honduh Chicken
Jan 28, 2005 04:44 PM
integraguy17
Feb 18, 2004 07:05 AM
Db8B18c1
Oct 14, 2003 04:01 PM
