gsr pistons in b16
Old May 28, 2005 | 07:41 AM
ghostskinner's Avatar
Default gsr pistons in b16
Is putting gsr pistons into a b16 a good way of lowering the compression and is it a direct bolt in
Old May 28, 2005 | 08:00 AM
Default Re: gsr pistons in b16 (ghostskinner)
bump
Old May 28, 2005 | 08:28 AM
leed's Avatar
I have done P72-ao pistons for 8.9-9.0ish C/R in a B16. Another option is USDM P73 pistons to achieve 9.7 C/R, but requires the rods to be machined 1mm on the small end or material taken from the wrispin area of the piston.
For me it was a cheap way of lowering the C/R a little and still retain my strange fetish with OEM internals.
Old May 28, 2005 | 10:58 AM
B00STED Si's Avatar
yes, the GSR pistons are the same for a b16, direct fit. theyre the exact same size, so JE doesnt even advertise pistons for the b16, they just have them listed for the gsr.
Old May 29, 2005 | 11:17 AM
bump
Old May 29, 2005 | 11:36 AM
_entropy's Avatar
If you're going to the trouble of swapping pistons you might as well go forged with some eagle rods while you have the motor apart. It's not that much more for forged pistons vs. new GSR's.
Old May 29, 2005 | 03:49 PM
urbansi's Avatar
Default Re: gsr pistons in b16 (Napoleon Dynamite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote">If you're going to the trouble of swapping pistons you might as well go forged with some eagle rods while you have the motor apart. It's not that much more for forged pistons vs. new GSR's.</TD></TR></TABLE>
word
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00STED Si &raquo;</TD></TR><TR><TD CLASS="quote">yes, the GSR pistons are the same for a b16, direct fit. theyre the exact same size, so JE doesnt even advertise pistons for the b16, they just have them listed for the gsr.</TD></TR></TABLE>
i wish i had known that earlier
Old May 29, 2005 | 04:55 PM
Default Re: gsr pistons in b16 (urbansi)
i got these gsr pistons for free and i heard that it was a good way to lower the compression in a b16 im dealing with all jdm parts here cause im from jamaica so when i swap the pistons i would get a compression of about 9.5: 1 which i think is good enough for a t3/t4 at 9psi
SurferDude905
Jun 13, 2009 06:42 AM
1993gsrcivic
Oct 3, 2007 11:31 AM
hondaeg8
Mar 19, 2005 12:37 AM
JDM23
Nov 21, 2003 04:08 PM
JBk24crx
Jul 30, 2003 10:28 AM
