Gsr nitrous build
This is what I have planned right now
Eagle Rods
Je or Cp Pistons 81.5mm bore( dont know what compression need help in that area)
Acl Bearings
Blox Type B Cam Shafts
Blox Dual Valve Springs
Skunk 2 Valves and retainers
68 mm throttle body
310 injectors
Walboro Fuel Pump
Wanting to run 75- 100 Shot of Wet Nitrous
Will be tuned on Crome
Will be my first build please leave negative comments out , Im a newb have done some research just wanting to see if I need to change anything ect , and know what compression I need to run for a DD and be able to run nitrous at the track. Car will have 91 octane ran through it all I have around here
Eagle Rods
Acl Bearings
68 mm throttle body
310 injectors
Walboro Fuel Pump
11.5:1 is good compression for daily.. With a good tune,you shouldnt have no problems on 91 pump gas.. I would run a higher octane on a 75 and up shots of nitrous..
hey i have the same set up but NOT RUNNING....idk if my piston compression is too low but i plan on shooting 200+ ....got some 9.5 cp pistons block is 84 mm sleeved cant find any info...but i guess if he said 11.5 is good i got to change them...thanks
lude98SH
43
Jan 16, 2007 07:38 PM
shazbot
40
Oct 5, 2004 10:15 AM
