GSR JRSC
Old Jan 11, 2007 | 08:49 PM
IamVtec's Avatar
Default GSR JRSC
I ran into another Problem..
when i tried putting the Lower part of the SC on it
hits the Coolant lines that run to the Block and the
Oil cooling sandwhich plate thing. Iam i suppose to
remove the oil cooling plate?
is it ok to remove the oil cooling plate? the one that the oil filter is screwed on
Old Jan 11, 2007 | 10:13 PM
Brad's Avatar
Default Re: GSR JRSC (IamVtec)
you are supposed to rotate it. step 103 in the instructions here : http://www.supercharger.com/gr...0.pdf
cluelessmale
13
Oct 25, 2012 06:28 PM
LitlGuy
Nov 8, 2007 09:06 PM
HYREV2NR
Aug 3, 2004 02:52 PM
