Gsr ignition timing
Old May 5, 2002 | 11:13 AM
DRAGLS's Avatar
Default Gsr ignition timing
what is the total advance on a 95 gsr is it 30 to 32 degrees. reason why i am asking is that i just put a ur race pulley on one. base timing is at 16 degrees.
Old May 5, 2002 | 11:29 AM
HipNot's Avatar
Default Re: Gsr ignition timing (DRAGLS)
i think total advance is higher than that,around 38
Old May 6, 2002 | 02:24 PM
DRAGLS's Avatar
Default Re: Gsr ignition timing (HipNot)
no that's to high it's either 30 to 32 degrees
Old May 7, 2002 | 12:41 AM
sparkz's Avatar
yeah it should be around 30-32
Old May 26, 2002 | 07:11 PM
GruvyTune's Avatar
New User
Default Re: Gsr ignition timing (sparkz)
HipNot is correct, stock ignition is as high as 38degree advance at about 8200RPM.
madcrx69
Apr 18, 2010 06:49 PM
4dooritr
Aug 8, 2004 06:56 PM
PTownGSR
Feb 22, 2004 09:21 AM
under_psi
Jul 9, 2001 11:16 AM
