gsr help
Old Sep 8, 2011 | 03:23 PM
gsrturbo-978's Avatar
Default gsr help
hi i have a built gsr turbo..today i started my motor and a min. later i smelled gas..so i immediately shut it off and the gas seems to be coming from where the injectors are...i just changed the o rings. what do you guys think should i replace the whole fuel rail and injectors or try to go cheap and figure out where it could be leaking. thanks any opinions will help
Old Sep 8, 2011 | 03:30 PM
boosted91crx's Avatar
Default Re: gsr help
you probably have a torn or bad o ring just take it all apart and check them out and put new as needed and put back together.
Old Sep 8, 2011 | 03:34 PM
yeah i just changed the o rings a couple days ago..its only here and there i will smell it, its not all the time
Old Sep 8, 2011 | 04:42 PM
Turbo-LS's Avatar
if your smelling fuel from near the rail the orings are leaking, did you spray them with a lubricant and twist while pushing the injectors into the rail? if not they easily pinch and tear
Hanmin
Apr 16, 2009 09:42 PM
Ronin150
Jul 18, 2005 01:40 PM
EGHatchy
Jul 8, 2002 01:35 PM
Hassan
Nov 7, 2001 06:37 AM
