GSR Differential strength???
Old Feb 24, 2004 | 07:42 AM
99B16Si's Avatar
Default GSR Differential strength???
i have a stock gsr tranny in my car and plan to put down around 400 on pump gas. i know im gonna have some serious traction problems and i eventually want to get a quaiffe but unfortunatley its not in my budget now. to sum it all up i just want to know how well the factory diff will hold up with a lot of power but definitely no slicks. and this is a daily driven 99si
Old Feb 24, 2004 | 08:04 AM
Evil DOHC's Avatar
Default Re: GSR Differential strength??? (99B16Si)
From our testing I have conluded that if you run a 25 or larger slick you will def. be in danger of breaking a diff with 300+ hp. I have broken both axles and a diff on 24.5x8x13's in a 350 hp integra, but I side stepped the clutch.
EVIL
Old Feb 24, 2004 | 08:19 AM
Austinbionic316's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">i have a stock gsr tranny in my car and plan to put down around 400 on pump gas. i know im gonna have some serious traction problems and i eventually want to get a quaiffe but unfortunatley its not in my budget now. to sum it all up i just want to know how well the factory diff will hold up with a lot of power but definitely no slicks. and this is a daily driven 99si</TD></TR></TABLE>
yeah I would like to know this as well, cause Im plaining on hittin 400whp max, but I would run around on 390whp on pumped gas with a FMAX stage 2 and its gonna be daily driven as well, but since I got the SI rims on some 15's. So wouldnt thicker 15's would be fine? or up the tire size?
Old Feb 24, 2004 | 09:14 AM
Evil DOHC's Avatar
Default Re: (Austinbionic316)
It will be fine but torque steer would be a bitch
Dont run slicks and your drivetrain will hold.
EVIL
Old Feb 24, 2004 | 10:10 AM
99B16Si's Avatar
Default Re: (Evil DOHC)
im not referring to slicks. i drive around on falken azenis pretty much yearround and dont lauch my car hard ever...even if i did it would just spin everywhere. but once traction occurs in 3rd or 4th i was curious if the amount of power going thru the diff will be too much for it.
Old Feb 24, 2004 | 10:18 AM
rocket256's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">im not referring to slicks. i drive around on falken azenis pretty much yearround and dont lauch my car hard ever...even if i did it would just spin everywhere. but once traction occurs in 3rd or 4th i was curious if the amount of power going thru the diff will be too much for it.</TD></TR></TABLE>
You should be fine because the car is in motion.
Old Feb 24, 2004 | 10:23 AM
Default Re: (rocket256)
ahh sweet, I get to keep my 15's
Old Feb 24, 2004 | 10:31 AM
rocket256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">ahh sweet, I get to keep my 15's</TD></TR></TABLE>
Yah, my friend David has the same promblem. But you he has a CTR tranny so he can hardly grab in the top of 3rd.
GSRBrent
Oct 26, 2007 08:48 AM
Jdm integra DB8
May 22, 2007 12:49 PM
B18Sleeper
Feb 8, 2007 05:41 PM
PhatBoy5015
Nov 7, 2006 04:21 AM
MattGSR
Feb 23, 2004 05:24 AM
