Greddy turbo timer install
Old Apr 11, 2005 | 01:01 PM
heygotboost's Avatar
Default Greddy turbo timer install
i bought a harness so it would be plug and play but the turbo timer isn't getting anypower . anyone have any answers ? could i have gotten a dead turbo timer fromn greddy ?
thanks
Old Apr 11, 2005 | 03:38 PM
Justateg's Avatar
i know you bought the harness so you didnt have to slpice, but why don't you try using a different wire for power.
Old Apr 11, 2005 | 11:47 PM
Evo-man@20psi's Avatar
Default Re: Greddy turbo timer install (94eg9)
I would splice just tape it up good all you need is power a good ground and the rpm sig/acc wire mine works great
Old Apr 12, 2005 | 03:19 PM
Well i know there's power getting to it, I moved the ground and the tt turned on for like 2 seconds and the display said off. Other than it won't stay on unless i move the ground wire, i have ground wire is attached to bare metal. Has anyone used a tt harness with a 92-95 civic?
Old Apr 12, 2005 | 07:44 PM
Justateg's Avatar
if when you move the ground it turns on doesnt that tell you its a grounding issue
rippinitup01
Mar 23, 2007 07:10 PM
b18tdelsol
Jun 7, 2002 12:47 PM
degradated
Nov 20, 2001 10:37 PM
