greddy turbo kit p1106 baro sensor code
Old Jun 8, 2005 | 11:03 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default greddy turbo kit p1106 baro sensor code
this is the second time i have seen this. p1106. the first car we fixed with hondata, but on this car we have a baro code. it didnt have it before so i dont think it is the ecu. any input would be helpful. t.i.a.
Old Jun 8, 2005 | 12:05 PM
Mr. Badwrench
Default Re: greddy turbo kit p1106 baro sensor code (boostedcivicsir)
bump
Old Jun 8, 2005 | 05:58 PM
Mr. Badwrench
bump please
Old Jun 8, 2005 | 06:30 PM
urbansi's Avatar
https://honda-tech.com/zerothread?id=1272600
might help??? both of us???
Old Jun 8, 2005 | 08:05 PM
PrettyLude's Avatar
its a faulty code, if you reset it, and it comes back, u have some issues
Old Jun 8, 2005 | 08:15 PM
Mr. Badwrench
Default Re: (PrettyLude)
not to be a smartass, but i know that, what i cant figure out is why it presents itslef after a blue box install. i mean there arent that many wires. 4 injectors, 2 map, hot, ground, and rpm. thats all.
Old Jun 9, 2005 | 04:50 AM
EE_Chris's Avatar
Default Re: (boostedcivicsir)
What voltage does the ECU see when you initially turn the key 'on'?
The ECU sees a modified voltage coming from the bluebox and if its a big enough difference from the Baro sensor, you'll usually get a code.
Old Jun 13, 2005 | 03:09 AM
Mr. Badwrench
thanks for the help, bump again though.
Old Jun 13, 2005 | 03:42 AM
EE_Chris's Avatar
What MAP voltage does the bluebox see during key on, engine off? What MAP voltage does the bluebox spit back out to the ECU during the same condition?
Old Jun 13, 2005 | 04:54 AM
Mr. Badwrench
Default Re: greddy turbo kit p1106 baro sensor code (EE_Chris)
thanks eechris. i will look at it when the customer comes back in.
kornkid21792
Jan 24, 2010 08:30 AM
d_boi_swag
Jul 5, 2009 12:14 PM
krz6jdm
Feb 21, 2006 01:36 AM
luciffer
Oct 4, 2005 05:44 AM
Mykizism
Sep 1, 2004 01:18 PM
