Greddy turbo-check engine light
Old Sep 2, 2004 | 05:05 PM
vtecgsr98's Avatar
Default Greddy turbo-check engine light
Have had my turbo kit on now for about 300 miles and i just got a check engine light. The code was P0171, system running to lean. The blue box that i am using(i know) has a green led on it to tell you if its running right, but mine is flashing, im not sure if it is suppost to flash or what. does any one else that is using the blue box know if theres is always green or is also flashing? Also do you think it might be my stock gsr fuel pump not being enough? Maybe its time for a Walbro255? Anybody.....
Old Sep 2, 2004 | 05:48 PM
VinceVTEC's Avatar
Default Re: Greddy turbo-check engine light (vtecgsr98)
the flashing green LED means its working properly. And usually blue box's make your car run ridiculously rich, not sure why yours is saying lean though... may want to check your wiring on the blue box and injectors
Old Sep 4, 2004 | 12:59 PM
movedon's Avatar
weak fuel pump...do you have any additional fueling? hoe much psi are you running?
vtecgsr98
Dec 24, 2005 11:21 AM
dynamicRacing719
Jan 17, 2005 06:15 PM
Blindstuff
May 3, 2004 04:18 PM
boostedblack99
Jun 16, 2003 10:20 PM
guyuenvy
Sep 12, 2001 07:07 AM
