greddy setup
Old Apr 22, 2002 | 03:56 PM
zexdrex's Avatar
Default greddy setup
whos running the greddy setup on stock internals (sohc or ZC) and what sort of numbers
ie. how much boost
ie. 1/4 mile times
ie. hp
Old Apr 22, 2002 | 04:10 PM
TurboSohc's Avatar
Default Re: greddy setup (zexdrex)
This kinda has been covered but let me try to help. On stock internals with the td04 15g turbo and fmic you can run anywhere between 5-10psi, the numbers will vary from person to person. There are alot of different ways to do this #1 would be getting yourself (once again) a hondata. This will be the safest and easiet. Second would be fpr,440cc injectors and a apexi afc. You can also just buy the greddy 2mm headgasket which will lower compresion and use a fpr/fmu and a afc. What I'm trying to get at is noway can really be wrong if you cant afford a standalone. Alot of people use diff combination's to turbos. 1/4 times depend on alot of things but with a bov/fmic and 8-10 psi on street tires your looking at low to mid 14's with slicks high 13's. Hp numbers will be from 150whp-180whp. Good luck I hope I helped.
Old Apr 22, 2002 | 04:35 PM
sushibug's Avatar
Default Re: greddy setup (TurboSohc)
i dont agree with that statement. why would someone spent $1400 for a turbo kit and then spend $1000+ for the engine management? at the most, i plan on getting a vafc + bigger injectors. i got quoted from AEBS for $1200+ for stage 2b. thats just ridiculous for 5psi.
Old Apr 22, 2002 | 04:46 PM
zexdrex's Avatar
Default Re: greddy setup (sushibug)
i was hopeN to run 7-10psi does the vafc controll boost and a/f
what about just the stage 2 hondata
BLKCivicPorscheStyle*
Oct 25, 2004 09:06 PM
Slvr_CRX
Aug 22, 2003 06:52 PM
eg686
Jul 24, 2003 07:17 AM
boostin4drcivic
Nov 7, 2002 12:23 PM
