Greddy kit modificatino question
i wanted to know if you could buy a greddy kit and then just use a bigger turbine than the one they give you. if i can, wouldn't it be the same as other turbo set-ups or do greddy's not give you enough power because on the manifold or other things?
the turbo is the reason it doesnt make much power (assuming you are refering to the sohc kit) but there isnt a lot you can do as far as turbos go that will give you substantially more power as far as I know
boostincoupe
Aug 28, 2002 05:23 PM
