Greddy kit just installed..Fuel problems...HELP!!!
well i just installed my greddy turbo kit to my d16z6 engine. well the problem is that i don't have the blue box. so what can i do to run safely 6lbs for now. I need to get the car running on the safe side. Would a walbro 255lph fuel pump do the job for (2-weeks) while my uberdata burner gets here. I also have a set of dsm 450 injectors but i have no safc and no fmu for now. I have to wait till my burner gets here so i was wondering if i could run the car with just the fuel pump or with just the injectors. Or can i run the fuel pump and injectors with out a controller for now?? thanks for your time.
the high flow fuel pupm wont make a difference. the injecotrs control how much fuel go into the4 engien not hte pump.
you can put the injectors in but it will probably not run well, wont idle and will stall a lot and make no power out of boost or little power in boost, and get terrible gas milage.
your best bet is to open the wastegate all teh way so it doesnt make boost and plan ahead next time.
xxscaxx
Mar 8, 2005 02:16 PM
