Greddy Kit
I read a write-up recently on a B16a Greddy kit that added 43 hp. To me, that seems kinda small. Is this to keep it smog legal? They said that the kit was. Is it b/c it's at low boost and could be cranked up a notch to higher psi w/o external addtions. Btw, I'd use an intercooler with it from the get go.
but my point is... is the Greddy kit capable with some tuning and the boost set a little higher, will the Greddy kit push 1 BAR (if I built the block a bit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptivaBlue »</TD></TR><TR><TD CLASS="quote">but my point is... is the Greddy kit capable with some tuning and the boost set a little higher, will the Greddy kit push 1 BAR (if I built the block a bit)</TD></TR></TABLE>
Yes. But you can run a T3/T4 at 8 psi and get the same amount of power as the small greddy turbo at 15 psi.
Apparently I need to do more research b/c I thought psi was psi and only delivery rpms (lag and what not) and overall capacity were the major differences.
I know that turbos have many different set-ups and variations but they are fundamentally the same, please no flaming.
GoFastHappy
Mar 17, 2004 09:57 PM
-BlueGSR-
Apr 24, 2003 09:52 AM
