Greddy heat shield bolt sizes?
Old Feb 26, 2004 | 06:23 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Greddy heat shield bolt sizes?
I have a used greddy SOHC kit, and I picked up a heat shield for it (the greddy one), but there weren't any bolts for it. What size bolts should I pick up that can fit in the manifold? Does anyone know the size offhand?
Old Feb 26, 2004 | 08:36 AM
Turbo E's Avatar
i think theyre metric thats about it. either 12mm or 13mm
Old Feb 26, 2004 | 09:28 AM
IN VTEC's Avatar
Default Re: Greddy heat shield bolt sizes? (boostincoupe)
A quick guess would be M8x1.25x25mm.
Old Feb 26, 2004 | 09:31 AM
ProEater's Avatar
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">i think theyre metric thats about it. either 12mm or 13mm</TD></TR></TABLE>
i think 12mm
Old Feb 26, 2004 | 04:26 PM
99blusi's Avatar
Default Re: (ProEater)
The dohc is 10mm...like every bolt on a honda is. I was using an a/c bolt to hold the shield on for a while...
Old Feb 27, 2004 | 02:28 PM
sl0w-m0's Avatar
Where did you get the heat shield? I need one
Old Feb 27, 2004 | 02:44 PM
MikeMAN's Avatar
im actually pretty positive its 13mm
mike
Old Feb 28, 2004 | 04:34 AM
NCchris's Avatar
Default Re: Greddy heat shield bolt sizes? (sl0w-m0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sl0w-m0 &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get the heat shield? I need one </TD></TR></TABLE>
me too
Old Mar 2, 2004 | 03:06 PM
Turbo E's Avatar
its just sheetmetal...goto a metal supplier buy a $2 sheet of 16 GA aluminum and use some tinsnips
Old Mar 2, 2004 | 03:13 PM
ProEater's Avatar
ok just bc there are 4 different answers on here im going to go check right now and verify
*will post correct answer shortly*
edit: i was incorrect, and the winner is.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi &raquo;</TD></TR><TR><TD CLASS="quote">The dohc is 10mm...like every bolt on a honda is. I was using an a/c bolt to hold the shield on for a while...</TD></TR></TABLE>
hellittymoto
Oct 13, 2004 01:11 PM
2 0 3
Dec 26, 2003 05:05 PM
Regalos420
Jul 31, 2003 01:55 PM
JalopySiR
Mar 29, 2003 08:59 PM
