greddy h22 manifold
Old Jul 1, 2006 | 12:53 PM
5thgenusmc's Avatar
Default greddy h22 manifold
I was told that a garret gt2871r would fit onto this manifold. Is this true?
Old Jul 1, 2006 | 01:58 PM
TheShodan's Avatar
Moderator
Default Re: greddy h22 manifold (5thgenusmc)
Since it is flanged with a T2, yes the turbo can fit onto the manifold. The rest is up to you on making sure it is properly clocked and fitted to that manifold.
Old Jul 1, 2006 | 02:29 PM
5thgenusmc's Avatar
so assuming that it does fit I will have to have a new downpipe made or will the elbow that comes with the greddy (restrictive one) fit onto that turbo?
Old Jul 1, 2006 | 03:33 PM
oscarmayer's Avatar
the DP opn the greddy kti is different, but with that gt28 you should run a full 3" exhaust system if your going to do more than like 9-10psi.
if your going for liek 9-10psi then you could get away with 2.5".
Old Jul 2, 2006 | 01:32 PM
5thgenusmc's Avatar
so it will fit the manifold but Ill have to make a new downpipe then correct?
Old Jul 25, 2006 | 02:45 PM
eggie75's Avatar
Default Re: (5thgenusmc)
i am considering the same thing...
the turbo and the dp will fit. the dp and flange are pretty narrow. 2" i think. check for clearance issues... the turbine seems to have room, but the comp is tight... maybe the 50 ar comp fit easier. wutever you do, let me know how it turns out!!!
clemsonteg
Jun 3, 2006 07:39 PM
blkeg2
Feb 11, 2005 07:03 AM
B00STeD
Feb 20, 2003 04:22 PM
Andrew 825SM
Sep 13, 2002 02:23 PM
sushibug
May 23, 2002 05:02 PM
