good nitrous piston ?
im looking for a good nitrous piston i was looking at je ? i have a 97 gsr and i wasent sure if i sould keep the stock compression or bump it up to 11:1 or 11:1 ?wat do you guys think ? and im looking to run prob a 75 wet shot
Bottles are for babies, J/K
Honestly any forged piston from a reputable company will due fine. Honda/acura guys have a great advantage over lots of other cars do to great head design and materials used. I was going to do a 12.5:1 nitrous car at one point but decided against it.
Look into CP, Wiseco, JE etc.
wat CR do u think i sould run ? i dont thinki want to go as high as 12:5 want do you think about 11:5 or 10:5 ? and if i do get i higher compression piston am i goin to need to do any head work ? sorry for all the questions its my first build
I would say that your limitation would be in the tune and the octane of gas that you have available. If you are trying to make a nice street car on spray head work always helps, but by no way will it hurt to leave the head unported. I have seen people run as high as 13:1 on 93 and get away with it for years.
Everyone will tell you that the tune makes all the difference blah blah blah, their right
As for your case, run 11.5 or lower, its honeslty the same, and its not like a point of compression is going to make a hugh difference here, unless you are going from like 8.0:1 to 15.1.
the only thing to worry about now is your cylinder pressure a properly functioning catch can setup should help.
