good bye cylinder 3
Old Oct 24, 2010 | 08:03 PM
NLR808's Avatar
Default good bye cylinder 3
was having some fun rolling some 3rd gear burnouts on street tires when i unleashed the spy hunter white smoke cloud. i guessed it was just the head gasket oh boy was i wrong, my koyo radiator looks like a puffer fish lol. and this
http://www.flickr.com/photos/31456909@N02/5112768471/http://www.flickr.com/photos/31456909@N02/5112768471/pistons are nice and smooth on top still, i knew the stock sleeves were the weak point in the motor but at only 413 hp didn't expect this.
i have another block but its a 82mm 11.1cr with stock sleeves not going to chance that maybe send this block out to be re sleeved
Old Oct 24, 2010 | 08:07 PM
cibao2ner's Avatar
Default Re: good bye cylinder 3
i cracked cylinder 4 on 11psi....will never run stock sleeves on 93 octane..i ran car hard for 6 months the one day i gas up in a different station than usual and boom the next day...also car felt weird and back fire going to 4th after i re fueled...so cant blame my tuner...go with 11.1 block but use e85..
Old Oct 24, 2010 | 08:20 PM
NLR808's Avatar
yea the fuel out here is garbage and theirs no way of getting e85 maybe high compression low boost just need to run race gas all the time.
Old Oct 24, 2010 | 08:32 PM
ShanghaiOC's Avatar
How much HP did you make & which turbo were you running?
Old Oct 24, 2010 | 08:45 PM
cibao2ner's Avatar
60-1 11 psi street tune very conservative to avoid the above...im guessing 270-300...engine was a stock 250k mile gsr long block...the last thing i expected to go was the sleeves..i was faster by a few cars than my friends 13.2 second turbo d16 on eg...so im guessing i was doing mid to high 12s...never made it to the track befor it blew..
Old Oct 24, 2010 | 09:05 PM
NLR808's Avatar
Wow I had a 60-1 also but with 16 psi lol
Old Oct 24, 2010 | 09:08 PM
Garage 808 Hatch's Avatar
sometimes the parts just give up. or you get bad gas
Old Oct 24, 2010 | 10:03 PM
ShanghaiOC's Avatar
****, I don't like hearing that. I have crappy California 91 octane. At least I picked up the Silver Surfer to cope with the gas I'll be getting
Old Oct 24, 2010 | 11:07 PM
Blue94Accord's Avatar
damn that sucks.
Old Oct 24, 2010 | 11:34 PM
slowtegkauai's Avatar
Is that the ball bearing reaper? GT3587R?
Old Oct 24, 2010 | 11:45 PM
crispchris's Avatar
250k is alot on a turbo'd stock block, maybe you could swap pistons on the other block to something with a lower CR, or get your block resleeved and you should be good to go
Old Oct 25, 2010 | 12:43 AM
norcalB18's Avatar
i'm so scared =(
Old Oct 25, 2010 | 07:07 AM
b18master's Avatar
IMG_0223
those pistons look to high to run on 93 octane gas...
Old Oct 25, 2010 | 09:14 AM
ShanghaiOC's Avatar
No, those are 2 different turbos. This one is more similiar to a s256, but it incorporates BW & Garret products. It's made by TheShodan on this board. I lived out in Pahoa & never saw anyone with a fixed up Honda on the big island
Old Oct 25, 2010 | 09:41 AM
Thats where a competent tuner comes into play. you can boost high comp, if the tuner knows what he's doing. we made 470whp on a 11:1 motor on 92 octane.
Old Oct 25, 2010 | 10:09 AM
per4mance's Avatar
yeah you can make that but at that compression on 92 there is no room for any detonation. So get a bad patch of gas and your f'ed. The # 3 cylinder in this pick is from the tune and not cause of stock sleeves. Any pump gas is 93 or below is so unpredictable.
Old Oct 25, 2010 | 10:49 AM
NLR808's Avatar
on that note when you coming back out here ;P
Old Oct 25, 2010 | 10:54 AM
I think james is heading back for a visit this month or next month.
Old Oct 25, 2010 | 10:57 AM
NLR808's Avatar
from the tune? the tops of the pistons are still nice and smooth and the pistons were 9:8:1 in the picture. Sometimes **** just breaks and **** broke rolling a third gear burnout id say it was a good way to go lol
but i do agree the gas out here is ****
Old Oct 25, 2010 | 12:33 PM
rich7777's Avatar
Can you post up a picture of the rad please ?
Old Oct 25, 2010 | 12:36 PM
Spawne32's Avatar
what psi and what size bore?
Old Oct 25, 2010 | 02:20 PM
NLR808's Avatar
ill get some of the radiator today, that was at 15 psi 81mm
Old Oct 25, 2010 | 02:36 PM
blackeg's Avatar
i blew a much bigger hole than that in a #3 stock sleeve making less than 400hp (boost creep is a biotch).
since then ive run sleeved blocks and had a few incidents that most defiately would have toasted stock sleeves, but i wound up with just blown headgaskets instead.
Old Oct 25, 2010 | 05:58 PM
NLR808's Avatar
http://www.flickr.com/photos/31456909@N02/5116489800/http://www.flickr.com/photos/31456909@N02/5116489800/is that bad?
http://www.flickr.com/photos/31456909@N02/5115887095/http://www.flickr.com/photos/31456909@N02/5115887095/
Old Oct 25, 2010 | 06:00 PM
Spawne32's Avatar
vrrrroooooom boom lol look at the bright side, at least your rings are good, that fluid is holding in there quite well
