Golden Eagle Vacuum Manifold install???
Old Jul 21, 2004 | 01:33 PM
masterasia's Avatar
Default Golden Eagle Vacuum Manifold install???
Hey...
I'm gonna install a Golden Eagle Vacuum Manifold.....
I noticed there are two .5 inch openings, one on each side.....
Can I run the brake booster line to one end and out the ther end...????
or do I have to "T" off the brake booster line and into the vacuum
manifold and seal up the other end of the vacuum manifold???
Old Jul 21, 2004 | 01:51 PM
swlabhot's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (masterasia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by masterasia &raquo;</TD></TR><TR><TD CLASS="quote"> "T" off the brake booster line and into the vacuum
YES.
Old Jul 21, 2004 | 01:53 PM
boosted_dc2's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (swlabhot)
i ran mine in series with the brake booster, before the check valve.
Landon
Old Jul 21, 2004 | 03:57 PM
Frozen E's Avatar
H-T White Ops
Make sure you hook into your brake booster line to the LEFT of that damn check valve. I had no idea there even was one. None of my vacuum powered stuff worked. The check valve is in the area of the hose that's just a little bit fatter than the rest of the hose.
As far as how to run it...both ways you described would work just fine.
Old Jul 21, 2004 | 04:03 PM
ladysman's Avatar
Old Jul 21, 2004 | 04:05 PM
specv5150's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Nice setup man...
Old Apr 12, 2005 | 05:15 AM
DMax013's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (specv5150)
Say I'm only going to use 3 or the 4 ports. Do I just cap off the one I'm not using? I have mine on the way so when it gets here I'm sure I'll have a better idea. I just noticed everyones using all 4 and was curious.
Old Apr 12, 2005 | 05:21 AM
IN VTEC's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (DMax013)
There's no need for plugs. The holes are sealed. You have to drill open the ports you want to use.
Old Apr 12, 2005 | 05:54 AM
RyanEJ8's Avatar
I ran my vacuum manifold off of the nipple on the intake manifold that used to be for my PCV. Easier than teeing into the brake booster.
Old Sep 14, 2005 | 04:38 PM
iconz116's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I ran my vacuum manifold off of the nipple on the intake manifold that used to be for my PCV. Easier than teeing into the brake booster. </TD></TR></TABLE>
Is there any difference in the vacuum readings by doing it this way? I'm about to install my Blox IM, and wondering how i should connect the Vacuum Mani.
Thanks
Old Sep 20, 2005 | 09:18 PM
91teggyman's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (iconz116)
here's my question if u install a boost gauge with boost and vacumm but not installed the turbo yet will it at least read vac or no i tapped into the vac hose from the map sensor ...this is such a noob question but im new to this crap so help me out guys
Old Sep 20, 2005 | 09:23 PM
Honda Sport's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (91teggyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91teggyman &raquo;</TD></TR><TR><TD CLASS="quote">here's my question if u install a boost gauge with boost and vacumm but not installed the turbo yet will it at least read vac or no i tapped into the vac hose from the map sensor ...this is such a noob question but im new to this crap so help me out guys</TD></TR></TABLE>
yes, it will read vaccum if you're not boosting yet. I have a boost/vaccum gauge on my car now with no boost.
Old Sep 20, 2005 | 09:24 PM
ccivic's Avatar
You tapped into the vacuum line coming from your MAP sensor?
The MAP sensor should have a dedicated vacuum source.. it's probably the most integral part of your car running related to vacuum.
Old Sep 21, 2005 | 01:02 AM
91teggyman's Avatar
Default Re: Golden Eagle Vacuum Manifold install??? (ccivic)
if thats the case then something is wrong cause its not moving
pjr710
21
Jun 11, 2008 12:33 PM
TehMan
Mar 20, 2006 12:49 PM
Willie
Jan 28, 2005 08:28 AM
InLimbo87
Jul 26, 2004 05:49 AM
FredoSP
Apr 12, 2004 09:21 AM
