golden eagle cam gear torque?
Old Jul 31, 2003 | 07:14 PM
GruvyTune's Avatar
New User
Default golden eagle cam gear torque?
on the golden eagle cam gears, the instructions say to torque the adjusting bolts to 20 ft-lb !! Is that for real? Those small bolts that much?
Old Aug 1, 2003 | 03:10 AM
GruvyTune's Avatar
New User
Default Re: golden eagle cam gear torque? (GruvyTune)
ttt
someone here must have these. at anywhere near that torque (ie 15ft-lb) it starts to deform the inner metal portion of the cam gear. I stopped torquing when i saw that happen. Already deformed one of these nice gears.
In addition, the main cam bolt says to only torque down to 37ft-lb. Seems like a lot less than stock torque.
i'll be in touch with GE today. So much for instructions.
Old Aug 1, 2003 | 08:52 AM
GruvyTune's Avatar
New User
talked to Ted at GE and apparently it's expected that the aluminum will deform under the torqued washers and they do like them torqed that much.
Old Aug 1, 2003 | 10:33 AM
kommon_sense's Avatar
is it just me or is the idea of deforming new parts upon installation a little unsettling, even if the manufacturer says that is the way it is supposed to be?
Old Aug 1, 2003 | 12:36 PM
93LSivic's Avatar
Default Re: golden eagle cam gear torque? (kommon_sense)
I wouldnt trust that torque number. Remember, this is the same guy that knows how to stretch gauge head studs
Old Aug 1, 2003 | 01:58 PM
GruvyTune's Avatar
New User
Default Re: golden eagle cam gear torque? (93LSivic)
who are you talking about? Ted at GE?
vince at GE also confirmed that it is expected for them to deform at 20ft.lbs and that this is normal and not to worry! jeeze, it was very unsettling to hear them crunching and deforming as i approach their stated torque.
yfz
Oct 21, 2009 11:40 AM
Jdmb16sir2
Oct 30, 2007 05:08 PM
LSR-Abuser
Oct 1, 2007 09:11 AM
GruvyTune
Aug 1, 2003 08:57 AM
FitCRX
Feb 5, 2003 11:47 PM
