going turbo, engine management?
Old Jul 24, 2003 | 06:52 AM
BIG RICH's Avatar
Default going turbo, engine management?
OK, well. I need to get head work, so I'm going to go turbo when it's done. I'm clear on just about everything needed to go turbo except for engine management. This an 89 CRX DX with a ZC swap. I've heard of ghettodyne, It's just a chip you add to your ECU. well I want it to be safe, I don't plan on pushing that much boost right now, I'm still using the stock block. maybe 10lbs. at the most. I just want it to run reliably. Any ideas?
Old Jul 25, 2003 | 08:03 AM
T4eg's Avatar
Default Re: going turbo, engine management? (BIG RICH)
Id would either go Motec, FAST, or Electromotive tec3. There are alittle pricey but well worth the money
Old Jul 25, 2003 | 11:35 AM
platinum00's Avatar
Default Re: going turbo, engine management? (BlueHatch00)
if you only running less then 10psi. use the vafc hack if you already have the afc.
works nice. do a search should have alot of info on it.
platinum.
Old Jul 25, 2003 | 01:33 PM
EFb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueHatch00 &raquo;</TD></TR><TR><TD CLASS="quote">Id would either go Motec, FAST, or Electromotive tec3. There are alittle pricey but well worth the money</TD></TR></TABLE>
ahhhh yes, the tec3...I remember when i got mine, which happend to be yesterday
Old Jul 25, 2003 | 01:54 PM
Mr Hammond's Avatar
a/k/a Jomo
Why? I mean yes it's nice and all, but why? The ZDYNE gold works very well as does the Hondata. They are very similar.
I am not a fan of AEM, Electromotive. FAST is a decent system. If you are going to spend the money I would look into Autotronic or MoTeC. Hell teh M4 Honda kit is $2,500. Not worth it IMHO for his set-up.
Old Jul 25, 2003 | 02:32 PM
2ltrsnailpwr's Avatar
FAst is nice if your going hard core- but system w/ the dig 7 ignition package is damn close to $3500 im personally goin w/ aem due to injector size-- aem handles it much better than hondata imo and it is cheap comparitivly speakin
Old Jul 25, 2003 | 04:20 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (B18egHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18egHatch &raquo;</TD></TR><TR><TD CLASS="quote">im personally goin w/ aem due to injector size-- aem handles it much better than hondata imo and it is cheap comparitivly speakin</TD></TR></TABLE>
Do you plan on running larger then 880's just out of curiosity?
Old Jul 25, 2003 | 04:56 PM
GSRswapandslow
Guest
Posts: n/a
just PM J.Davis
tell him Rob sent you for a great deal
Old Jul 27, 2003 | 08:11 PM
Im running 96lb injectors so yes a couple hundred cc's more
Big red89
Sep 30, 2007 05:03 PM
PnoyJeff
Jan 26, 2005 03:22 PM
DenizenSays
Sep 21, 2004 03:36 PM
illogic65
Aug 26, 2004 11:00 AM
lunarcry
Aug 1, 2003 06:50 PM
