going for final tune.... suggestions?
Old Apr 7, 2015 | 09:46 PM
roll8221's Avatar
Default going for final tune.... suggestions?
Currently have about 100 miles left on the break-in period on my b18c1 turbo and about to bring it for the final tune and turn up the turbo... still deciding how far i want to push it... i want to get as much power out of it but without great risk of blowing it up... heres the internals,
-stock sleeves
-Hasport Mounts
-CP Pistons 81.5
-Manley rods
-ACL bearings
-ARP main and head studs
-Supertech valves, springs, retainers, guides, seals
-Supertech block gaurd
-Clutchmasters 6 puck stage 4
-Aeromotive 340 fuel pump
-AEM fuel rail
-AEM fuel pressure regulator
-ID725 injectors
-Skunk 2 pro intake mani
-Skunk 2 70mm alpha throttle body
-Precision6262 Turbo
-Mishimoto G Line 24.5" x 11.75" x 3" intercooler
-HKS BOV
-OEM gaskets, oil pump, water pump
-Moroso 5.5 qt oil pan
-stock crank, cams
-accel coil
-premium pump gas (no e85 here)
How much should i shoot for and what psi? In your opinions...
Old Apr 7, 2015 | 10:14 PM
yungkhmer's Avatar
Default Re: going for final tune.... suggestions?
Id shoot for 280-300 whp. Thats more than enough for the streets. Thats a big turbo though. And why the block guard?
Old Apr 7, 2015 | 11:36 PM
roll8221's Avatar
It was recommended by my machine shop as an alternative to sleeving, i wanted to get as much horsepower as i could witbout sleeving... all internals are forged, c.r. is about 9.5:1.... sorry, forgot to add that in the original post...
Old Apr 7, 2015 | 11:46 PM
king06's Avatar
That is a huge turbo so I don't see a problem getting 400-450 out of it. Friend got his car tuned at Locash racing here in Phoenix and made 470 on 91 and a .50? trim and a tiny intercooler it was sleeved though.
Also, we built the motor idled it made sure it didn't leak and got it broken-in and tuned on the dyno. Took it home changed the oil and beat the hell out of it. Good luck
Old Apr 8, 2015 | 06:37 AM
boosted94gsr's Avatar
That looks like a pretty solid setup. Stock sleeves is your limiting factor. Go for 500whp on pump gas if you have a good tuner then you can alway turn down the boost to 350-400whp range for the street.
Old Apr 8, 2015 | 06:50 AM
tooslohatch's Avatar
What he said ^^. I would like to emphasize his call-out of a GOOD tuner. I would use race gas at those numbers though.
Old Apr 8, 2015 | 07:27 AM
Yes agreed. I would not recommend daily driving it at 500whp on pump gas with stock sleeves. Race gas is best for this power level especially with stock sleeves. 350-400whp on pump should be no problem daily on your setup.
Old Apr 8, 2015 | 07:56 AM
roll8221's Avatar
Thanks, ill try to post some numbers post-tune....
Old Apr 8, 2015 | 03:55 PM
turbo8832's Avatar
I love to see that your using a 6262 good luck man love that turbo you will make good numbers but like all said above the sleeves will limit you good build
Old Apr 8, 2015 | 09:54 PM
roll8221's Avatar
Yeah, seeing that now... hind sight is always 20/20...
Old Apr 11, 2015 | 06:24 AM
hybrdthry911's Avatar
-stock sleeves
-Hasport Mounts
-CP Pistons 81.5
-Manley rods
-ACL bearings
-AEM fuel rail
-ID725 injectors
-HKS BOV
-stock crank, cams
-accel coil
You injectors will actually be the limiting factor. You will run out of fuel around 450whp.
Could have done without these parts:
Moroso oil pan
+ Arp main studs included the required line hone(make sure you clearanced the oil pump)
+ accel coil
+ Blockguard
= Sleeves
roll8221
Nov 4, 2015 07:11 PM
SergieL
26
Jan 26, 2015 07:31 AM
jarrodsi
Oct 9, 2013 12:02 PM
roll8221
May 13, 2013 12:10 PM
roll8221
Mar 18, 2013 04:38 AM
