GM 3 bar map sensor will not idle? help?
So I purchased a GM 3 bar map sensor and installed it using the guide on hondata.com
The car would start but I would have to give it a little gas to get it to stay running but it ran lean.
I plugged the stock map snesor back in and it idles fine.
What am I doing wrong?
O and the 3 bar is tapped into the harness so I have both plugs still Im just using one at a time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">you need to change the tune. You cant pop it in and expect it to run.</TD></TR></TABLE>
So even though the basemap is programeed for it, it still shoudnt idle?
wilham320
Engine Management and Tuning
Jun 10, 2009 08:25 PM
null.
Dec 15, 2005 06:35 PM
89civic1.8T
Jul 12, 2002 11:22 AM
