Glowing turbo manifold? is this normal?
Old Feb 25, 2004 | 11:28 PM
turbolsintegra26's Avatar
Default Glowing turbo manifold? is this normal?
Ok, Is it normal for the turbo manifold to glow, I can only see it when I pull over immediatly and its fairly dark. I'm running a drag turbo kit on my Integra B18B, I have a EGT guage, and the temp. probe is about 8-10 inches from the top of the down pipe( I know it should be closer, is that a huge deal?). I'm getting up to 1200 F. cruising down the highway, and 900-1000 F around town. My cam timing and ignition timing is set perfect( Stock ). I'm not running any boost, because I'm waiting for Hondata to arrive, so Its not because I'm pushing it hard. My spark plugs show that the fuel mixture is pretty good and fuel efficientcy is normal, my car is set up and driven like a stock integra for the time being. I just want to know if this is normal, and if so, cool. If not give me some Ideas, and any other ideas you might have...
Thanks Justin
Old Feb 26, 2004 | 04:18 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Glowing turbo manifold? is this normal? (Turbointegra22)
-bump-
i would like to know too..
Old Feb 26, 2004 | 04:26 AM
dasher's Avatar
yes, its normal... you tend to notice it after you quickly pull to the side after a few runs and its dark outside ...
Old Feb 26, 2004 | 04:53 AM
Gravy's Avatar
Default Re: Glowing turbo manifold? is this normal? (dasher)
here is a nice pic of a glowing manifold. this was on the dyno tuning the haltech.
Old Feb 26, 2004 | 05:21 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Glowing turbo manifold? is this normal? (Gravy)
thats an awesome picture..
thanks for the info!
Old Feb 26, 2004 | 05:43 AM
Silverbeast's Avatar
SS manifold, like the max rev, etc. seem to heat up easily and glow often. I know I thought the same thing when i had mine. I pulled over on a cold night and saw red glowing under the hood and thought WTF. Dont worry though, usually it's from a poorly designed manifold or hard running.
Old Feb 26, 2004 | 05:44 AM
mitch83's Avatar
Default Re: Glowing turbo manifold? is this normal? (kKdARIAN)
bad *** pic.
mitch
Old Feb 26, 2004 | 05:46 AM
DaX's Avatar
DaX
Loved
Community Favorite
Nice picture.
Old Feb 26, 2004 | 07:27 AM
Bailhatch's Avatar
Default Re: (DaX)
It can be from running too rich also. I did an RX7 Turbo II motor swap (stock for stock) the o2 sensor wire had broken inside the harness and it was making the manifold and turbo glow bright red even with the WG open all the time. Fixed the wire and it no longer ran pig rich or glowed...until the WG was put back a few weeks later
Old Feb 26, 2004 | 04:46 PM
EtaK's Avatar
would love to see a pic. of a lovefab glowin'.
Old Feb 26, 2004 | 05:11 PM
Tinker219's Avatar
Default Re: Glowing turbo manifold? is this normal? (Sepulcher)
I should get my Shorty on the SRT4, that thing glows at idle
Old Feb 26, 2004 | 05:13 PM
boostin GSR's Avatar
Default Re: Glowing turbo manifold? is this normal? (Tinker219)
glowing manifolds kick ***
Old Feb 26, 2004 | 09:02 PM
rezo's Avatar
Default Re: Glowing turbo manifold? is this normal? (boostin GSR)
yes your egt gauge shoulda been closer.. on my b18c1 (egt gauge about 6 inches from motor) before i installed the turbo the egt would get up to 1450*F.. just installed my turbo so i havent hit it hard yet to see an increase in EGT, though ive heard EGT on turbo cars get way hotter than others...
btw heres a vid of an an evo on a dyno: http://www.thugbuilder.net/fil...d.wmv
now THATS a hot manifold
Old Feb 26, 2004 | 09:11 PM
JdM_y0's Avatar
HOLY MOTHERF**KING ****!!!
*jaw drops* u need to watch that vid.
Old Feb 26, 2004 | 09:12 PM
turtle-eg's Avatar
Default Re: (Silverbeast)
Won't a glowing manifold cause a huge fire hazard? Also for those of you who are running a cat. converter, won't the high temperatures cause the cat to melt and clogged?
Old Feb 26, 2004 | 09:14 PM
Nid Styles's Avatar
Default Re: Glowing turbo manifold? is this normal? (rezo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rezo &raquo;</TD></TR><TR><TD CLASS="quote">yes your egt gauge shoulda been closer.. on my b18c1 (egt gauge about 6 inches from motor) before i installed the turbo the egt would get up to 1450*F.. just installed my turbo so i havent hit it hard yet to see an increase in EGT, though ive heard EGT on turbo cars get way hotter than others...
It should actually be 3" from the motor. On the #3 cylinder.
Old Feb 26, 2004 | 09:40 PM
Full-Race Javier's Avatar
NA headers glow too
http://www.renaultf1.com/en/pu....html#
Old Feb 26, 2004 | 10:19 PM
hpfsi's Avatar
Default Re: (Full-Race Javier)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Javier &raquo;</TD></TR><TR><TD CLASS="quote">NA headers glow too
Very nice... funny though, my remote engine test facility looks nothing like that Man I could watch those injectors all day - very fascinating.
b18cx's Avatar
Now that F1 vid rocks!!!!!!!!!!!!!!
Old Feb 26, 2004 | 11:17 PM
Nick7's Avatar
http://www.renaultf1.com/en/pu....html#</TD></TR></TABLE>
Sexy!
Old Feb 27, 2004 | 12:01 AM
Broken Gearbox's Avatar
Default Re: (Nick7)
Nice vid.
Cool pic.
Old Feb 27, 2004 | 05:10 AM
Thanks for everyones input, I guess everythings fine, I'm having a custom 3 inch down pipe made, and I'll properly position my EGT probe up at the top. I have a cast iron manifold and I dont want to drill, and tap it into that. What is every ones opinion on Thermal wrap on the manifold or down pipe, I know it makes a big difference on under the hood heat, but does it have any down sides?
Thanks again for all the responses,
Justin
Old Feb 27, 2004 | 05:17 AM
Tinker219's Avatar
Cast iron glows MUCH easier than welded tubing...at least from my experience.
you should have seen the stock SRT4 manifold/turbo. No wonder they use 3 heat shields!
Old Feb 27, 2004 | 05:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
Nice vids!
Old Feb 27, 2004 | 07:15 AM
hybrid93SIvic's Avatar
Default Re: (DaX)
i dare someone to touch it
