Ghetto rig i/c piping...
Just wondering... who has used or made their own piping for i/c and charge pipes outside of a muffler shop ?
Anyone used something other than metal ?
How has it worked out for you... pics would be fun.
X2
X2
Am I mistaken or is that an elbow in your avatar?
My piping is a conglomeration between radiator hose and mandrel bends from JC whitney. It works fine and with some flatblack rattle can it looks pretty tight
My charge piping is a combitnation of drag pipe, flexible exhaust pipe, and stock charge pipes
offtopic:
your sig is offending the homo's on this site (mainly joseph d), you should change it. That and i only like lookign at **** at night
offtopic:
you can get the pipes from jc whitney cut and use silicon hose adapters i know the iam7head guy was selling some nice hose cheap
X2
www.toohighpsi.com 24 psi, works fine for the budget 351W Capri, that ran low 10's at that time. It now runs high 9's, faster actually but Mike lacks $$$ for safety equipment, off a Holset HX40 at 18 psi.
Everyone has an expert opinion on how PVC pipe works, none of them firsthand. Mine's held for 15K miles, and it does not become brittle.
[Modified by J. Davis, 7:40 AM 4/5/2003]
get jc whitney aluminized steel mandrels.... cut/fit them onto your car, mark where they need to be welded, and take them to someone with a welder to weld up...
why do you put "X2" at the endo f all of your posts? Its very annoying.
Your very annoying
Your very annoying
so how does it feel being king of the n00bz abaz?
Ever seen H-T Bambi ?
Thumper says, "If you don't have anything good to say... then STFU..."
X2 (Resident A-hole
