Getting rid of PCV SYSTEM succesfully??
Old Sep 15, 2002 | 03:37 PM
TurboDANDEE's Avatar
Default Getting rid of PCV SYSTEM succesfully??
I was wondering if there's a way i can get rid or disconnect the PCV valve system (black box behind the block) without causing any damaged to the motor. Its a boosted GSR so I feel I have no use for it and replace it with a catch can from GReddy. Its makes the motor look alot cleaner and I've seen some done in magazines and I was wondering what they did with it (black box). If there's a way, can someone please guide me to it since my motor is out, it would be much easier to do. Pics would also be nice, thanx in advance.
Old Sep 15, 2002 | 03:42 PM
93LSivic's Avatar
Default Re: Getting rid of PCV SYSTEM succesfully?? (JiSATSU RaceR)
Good thread Lets hear some replies. I would like to know about this too.
Old Sep 15, 2002 | 04:00 PM
Dee's Avatar
Dee
Default Re: Getting rid of PCV SYSTEM succesfully?? (93LSivic)
The Greddy can is an unbaffled bling bling show item. Why would you want to remove the PCV? Without the valve the crankcase would become pressurized causing premature ring failure. Nobody sees the OEM oil catch anyway so why wory about it? The best bet for a street car would be to use the baffled Moroso catch can in conjunction with the OEM oil catch. This subject has been discussed a kazillion times so there should be lots of info in the archives.
Old Sep 15, 2002 | 09:50 PM
Flamenco-T's Avatar
Default Re: Getting rid of PCV SYSTEM succesfully?? (Dee)
no shiet, the greddy catch can is basically a soda can, capped on both ends and run 2 lines through it....
if you open the can, it's is completly empty, I like MarkC's idea, use a 99 cents auto zone fuel filter heheheheh
use moroso or any baffled can...
EdSales
Aug 17, 2011 07:39 PM
s bourgault
Aug 29, 2010 08:23 AM
VtecKiDD
114
Dec 11, 2007 05:50 PM
stevel
26
Jul 19, 2004 11:51 PM
TurboDANDEE
Sep 15, 2002 07:26 PM
