Getting Close - Last Minute Details Needed
Old Aug 31, 2005 | 06:53 PM
tucked_civ99's Avatar
Default Getting Close - Last Minute Details Needed
Just wanted to let everyone know I'm getting pretty close to finishing my setup. Got a 200 -220HP goal in mind (long-term). I'll take what I get out of this setup for now. Please give me some advice if it sounds like i need it...
FYI - Got a 1999 EX - D16y8 - 80K mi
Here's what I've accumulated so far:
Garrett T3/T04 (50 trim .48 a/r) - http://www.cheapturbo.com
ACT XTSS Clutch Kit - http://www.turboimport.com
Tial 38mm Wastegate .5 bar Silvertop - http://www.nolimitmotorsport.com
A/C Log Exhaust Manifold (externally wastegated) - http://www.bmcrace.com
3" Downpipe/Dumptube Combo - http://www.bmcrace.com
JRC 6" Intercooler - http://www.johnnyracecar.com
Oil Feed/Return Kit - http://www.stealthmode.com (tuner toys)
450cc Correctinject Injectors - http://www.stealthmode.com (tuner toys)
Chipped OBD1 ECU - http://www.stealthmode.com
I am a few months away from starting my install (I'm waiting to purchase a second car). You guys have anything good or bad to say about what i have so far?
Here's what is next in line to purchase:
HKS SSQV BOV
Charge Pipes/Clamps/Couplers
Vacuum Manifold & Lines
Colder Spark Plugs
Missing Link or 2bar Map Sensor (not sure what I need to do here...)
OBD2->OBD1 conversion harness
Fuel Pressure/Oil Pressure/Boost Gauges
Resurface Flywheel (for the new ACT clutch)
Oil Pan Gasket
Chip Burner
Heres what i think i can do without for a while:
ARP Head Studs
Head Gasket
Pistons
Rods
Fuel Pump
I plan to tune this thing with uberdata or crome. Here is what I think I have to do to get this thing up an running after the install. Is this way of thinking correct? -->
0) Install all hardware (turbo system and injectors)
1) Install chipped OBD1 ECU (attached with a conv harn)
2) To program, I will need uberdata, and a chip burner...
3) Create a basemap using uberdata on my PC...
5) Burn chip ...
6) Reinstall programmed chip into ECU...
7) Start car? Take it to get proffesionally tuned?
My main concern is getting the car up an running after hardware is installed... please help a cuban out here!
Old Aug 31, 2005 | 07:04 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Getting Close - Last Minute Details Needed (tucked_civ99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tucked_civ99 &raquo;</TD></TR><TR><TD CLASS="quote"> Start car? Take it to get proffesionally tuned</TD></TR></TABLE>
Yes, burn a 450cc injector map keep the car out of boost while you drive it to the tuner.
Old Aug 31, 2005 | 07:08 PM
Default Re: Getting Close - Last Minute Details Needed (Adi Raaa)
Thanks for the reply.
Any input on if i need a higher bar map sensor, missing link, or neither?
Old Aug 31, 2005 | 07:10 PM
JDM_EH2's Avatar
ur gonna need the fuel pump...
Old Aug 31, 2005 | 07:39 PM
af-performance's Avatar
Banned
Default Re: Getting Close - Last Minute Details Needed (JDM_EH2)
Sent you a pm.
https://honda-tech.com/zerothread?id=1264747
Old Sep 1, 2005 | 08:24 AM
Default Re: Getting Close - Last Minute Details Needed (af-performance)
Sorry, I dont have much experience posting on Honda-Tech forums. How do I check my PM's? Either I'm looking in the wrong place or i don't see the link to checking PM's on my screen anywhere.
Thanks.
Old Sep 1, 2005 | 08:28 AM
King Tut33's Avatar
PMs come up as a popup as soon as you get one. If you have a pop up blocker then you might have missed them. Click on My Profile-&gt;Instant Message History to check your recent PMs.
Old Sep 1, 2005 | 08:52 AM
Default Re: Getting Close - Last Minute Details Needed (King Tut33)
Thanks. I saw the instant message link, but didnt think it was the same as a personal message.
But anyhow, i got his PM.
Old Sep 2, 2005 | 03:52 PM
yee SERIOUS's Avatar
sounds good to me. maybe u might want that fuel pump now though
ALLMOTA92EG
Feb 6, 2009 10:08 AM
ALLMOTA92EG
Jan 27, 2009 12:24 PM
hybridb18
Nov 14, 2005 12:58 PM
abraunb16
Jul 12, 2003 09:55 AM
