Garrett turbo starter kit
Old Aug 22, 2004 | 02:29 PM
foolintherain617's Avatar
Default Garrett turbo starter kit
I did some searches and even googled it but didnt come up with anything for basic terms and definitions on the contents of a turbokit. I recently looked at the add on HT for cheapturbo.com and I saw their garrett start kit and basically i do not know what it comes with or what the codes stand for where you make your decision on what to buy. Im looking to get started with turbo and i thought this might be a good way to go. Any help on explaining what this comes with and what it can do for my car will help.
Im probably gonna get flamed for this but any info will help.
Old Aug 22, 2004 | 05:36 PM
Chris F's Avatar
Default Re: Garrett turbo starter kit (foolintherain617)
http://www.superhonda.com/foru...65685
Subject: turbo kit prices and what's included
Greddy - MSRP $1,995.95 and up
http://www.greddy.com/products...c.jpg
Applications:
1992-95 Civic EX
1999-00 Civic Si
1997-99 Prelude Non-SH
1996-99 Integra GSR
1994-95 Integra GSR
1996-99 Integra LS/RS
Includes the following:
Cast Manifold
downpipe
internally wastegated turbo
FCU
320 cc inj
piping
Intake air filter assembly
hoses oil lines and misc. hardware
Drag - list price 3,499.00
http://www.dragturbokits.com/i...y.jpg
Applications:
Acura Integra 1990-1993 All *
Acura Integra 1994-2001 RS/LS/GS
Acura Integra 1994-2001 GSR
Acura Integra 1997-2001 Type R
Honda Accord 1994-1997 4 Cyl **
Honda Prelude 1992-1996 S/SI **
Honda Prelude 1992-1996 ***** **
Honda Prelude 1997-2001 ALL **
Honda Civic/CRX 1988-1991 ALL *
Honda Civic/CRX 1988-1991 W/ B-18 B Motor *
Honda Civic/CRX 1988-1991 W/ B-18 C Motor *
Honda Civic/CRX 1988-1991 W/ B-16 A Motor *
Honda Civic/CRX 1988-1991 W/ B-16 Motor *
Honda Civic 1992-1995 DX
Honda Civic 1992-1995 EX/Si
Honda Civic 1996-2000 DX/LX/CX
Honda Civic 1996-2000 EX
Honda Civic 1996-2000 SI DOHC
Honda Civic 1992-1995 W/ B-18B Motor
Honda Civic 1992-1995 W/ B-18C ***** Motor
Honda Civic 1992-1995 W/ B-16A Motor
Honda Civic 1992-1995 W/ B-16 Motor
Honda Civic 1996-2000 W/ B-18B Motor
Honda Civic 1996-2000 W/ B-18C ***** Motor
Honda Civic 1996-2000 W/ B-16A Motor
Honda Civic 1996-2000 W/ B-16 Motor
Honda Del Sol 1993-1997 SOHC
Honda Del Sol 1994-1997 DOHC B-16A
Honda Del Sol 1993-1997 W/ B-18B Motor
Honda Del Sol 1993-1997 W/ B-18C Motor
Honda CRV 1997-1998 ALL
* Special Order
** Discontinued pending availability of Generation 4
Includes the follwing:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
Greddy Type S Blow off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
Installation manual
works with automatic or manual transmission.
works with air conditioning.
Revhard - MSRP: $2,799.99 and up
http://www.revhard.com/turbokits/kit3.jpg
Applications:
88-91 Civic/CRX (D Series Motors)
88-91 Civic/CRX (B Series Motors)
92-00 Civic (D Series Motors)
92-00 Civic (B Series Motors)
90-93 Integra
94-00 Integra
Stages:
Revhard offers 4 different stages to suit your driving and financial
needs. Stage 1 offers an outstanding quick spool up ideal for street
use, however it limits horsepower compared to Stage 2, which offers
a bigger turbo and intercooler for more horsepower. Rev Hard presents
an all new kit Stage 2C. Designed for beating out the competion and
accomplishing extreme horsepower for the street/race conditions. To
produce the all out race power for the race enthusiast, go with the
Stage 3
Stage: 1
Use: Street
Part #: RHSTG118
MSRP: $2,799.99
Boost Level: 7psi
Injector Size: Stock
Horsepower/Torque: +65 / 215 ft/lbs
Includes:
Rev Hard Cast Iron Manifold
Rev Hard T3 Garrett Turbo
Turbonetics Deltagate (5-7 psi)
Vortec Blow Off Valve
2.25" Aluminzed Mandrel Bent Piping
2.5" Downpipe
Progressive Fuel Regulator
High Volume Fuel Pump
Purosil Hoses and Clamps
Steel braided -3 Oil line
Oil Return Line
High Pressure Fuel Line
High Pressure Silicon Line
Necessary Vacuum Lines
Necessary Vacuum Tee's
Stage: 2
Use: Street/Track
Part #: RH18IT
MSRP: $3,599.99
Boost Level: 9psi
Horsepower/Torque: +120 / 285 ft/lbs
Inlucdes:
Rev Hard T3/T04E Hybrid Turbo
Rev Hard Intercooler
Deltagate (9-12psi)
2.5" Downpipe
Progressive Type Fuel Regulator
Purosil Hoses & Clamps
Steel Braided -3 Oil Line
Oil Return Line
High Pressure Silicon Hose
Neccessary Vacuum Tee's
Neccessary Vacuum Lines
Stage: 2C
Use: Street/Track
Part #: RH18ITC
MSRP: $3,799.99
Boost Level: 9psi
Includes:
Rev Hard Cast Steel Tubular(no AC)
optional Cast Iron Manifold(w/ AC)
Rev Hard 2C Intercooler
Deltagate (9-12psi)
2.5" Aluminum Charge Pipe
2.5" Downpipe
Oil Return Line
Stage: 3
Use: Track
Part No.: RHRACE
MSRP: starting $4,499.99
Boost Level: 25psi
Injector Size: 990cc (Low Impedence)
Horsepower/Torque: 550+ / 395 ft/lbs
Includes:
Rev Hard Equal Lenth Steel
Optional EL Stainless Manifold
Premium Hypo (500+hp)
Racegate (9-12psi)
Godzilla Blow Off Valve
2.5" Downpipe
Oil Return Line
Fmax - $3799.00
http://www.f-max.com/civic1.jpg
Available Applications:
92-95 Honda Civic D16
96-00 Honda Civic D16
92-00 Honda Civic B16A, B17, B18B
92-00 Honda Civic B18C1
92-93 Acura Integra B16,B17,B18
94-00 Acura Integra B18C1 GSR
94-00 Acura Integra B18B LS
92-00 Honda Prelude H23A
92-00 Honda Prelude H22A
97-00 Honda Prelude H22A4
94-97 Honda Accord , 2.3L
98-00 Honda Accord 2.2L VTEC
88-91 CRX/CIVIC
Icludes the following:
FMAX High-Carbon Cast-Steel manifold
Closed-Loop Mandrel Bent Downpipe
Intercooler Piping
Intake Pipe
T3/T4 Hybrid Turbocharger
Deltagate External Wastegate
Intercooler
A K&N filtercharger
HKS Racing Bypass Valve
Additional Injectors
ERL MF2 Addictional Injector Controller
MSD-BOOST TIMING MASTER
rideal Head Gasket
Full Race - $3,899.00
http://www.full-race.com/produ...3.jpg
Applications:
none listed
Includes:
Full Race Equal Length Manifold
Full Race "Back Door" Intercooler
Full Race Downpipe
Garrett T3/60-1 Turbo or Garrett T4/T04E 60 Trim Turbo
Tial 40mm Wategate
Tial 50mm Blow Off Valve
Aluminium Intercooler Piping
Full Race Oil Line Kit
Silicon Couplers / Hose Clamps
MaxRev - $2,899.00
http://www.maxrev.com/photos/1036605510_1.jpg
Applications:
none specific
Includes:
Large front mount intercooler
Do it yourself piping kit
Maxrev billet Blowoff valve and mnt
stainless oil line kit
stainless steel B series manifold
2.5 inch stainless downpipe
Tial wastegate
Garrett t3 to4E 57trim stage 3 turbo good for 400+hp
Hardware-clamps,couplings,small hose and T fittings
Old Aug 22, 2004 | 05:38 PM
VTteg's Avatar
Tell us your overall horsepower goal, your budget, where you want your power band to be, and your willingness to peice a kit together yourself. You will almost always save money by piecing your own kit together, and since you selected all the parts, your overall goals for your car will be satisfied better.
If you are truely lost as to some of the terms involved with a turbo setup, look here: http://www.cse.uconn.edu/~yele....html
Its a site i stumbled across not too long ago.
Also, this previous thread was extreamly helpful as well: https://honda-tech.com/zerothread?id=523242
read those and then as us a few more specific questions.
Hope i helped a little
Old Aug 24, 2004 | 05:41 PM
Default Re: Garrett turbo starter kit (94SlowTec)
Im looking between 50-75Hp to start and I have about $2k. Powerband im looking about mid range, if thats appropriate for every day street use. As far as putting it together by myself, what I gathered from the site you gave me showed me i probably dont have the skills or tools to do it so i would need some assitance.
Those sites helped a lot Thanks
dvs94Teg
Apr 27, 2009 09:06 AM
mtownsi
May 18, 2006 08:10 AM
NITERYDER
May 22, 2004 09:46 AM
