fully built dart block
Old Feb 7, 2010 | 07:16 AM
turbocrxdart420's Avatar
Default fully built dart block
I just got my motor back and i dont wanna get charged hella for this start up and tune. The tunning shop by me is king motorsports they wants to start my motor up and break it in but i dont wanna get stuck with a huge bill. Any input would be nice
Old Feb 7, 2010 | 07:17 AM
d112crzy's Avatar
Default Re: fully built dart block
Stop being cheap. Either learn how to tune your own motor properly, or fork over the money to do it right.
Old Feb 7, 2010 | 07:48 AM
cheap your cheap maybe i should say that again as far as the first start up i wanna do it just to make sure its gonna start and its got all the fluids not that they are chargin me fo lil stuff you know.
Old Feb 7, 2010 | 05:09 PM
TylerB's Avatar
D112 is right, you're cheap. If you want cheap, get a basemap and have fun!...for a day or two.
Old Feb 7, 2010 | 05:21 PM
boostedEF91's Avatar
Put your motor in your car and break it in. whats so hard about that.?? why would you have someone else break in your motor.?? do you not know how to put a motor in and start it up. drive it around a lil. go get it tuned.
Old Feb 8, 2010 | 07:02 AM
rip94delsol's Avatar
you need a basemap, if you just start meesing with the map to just get it started you might lean it out and fry something or you might wash down the cylinders with gas. Then you whole build has gone down to crumbles.
there just gonna put a basemap then start it up and then tune it! should be around a grand if your using Hondata.
why would you want to waste a expensive motor just for not doing it right!
Old Feb 8, 2010 | 07:56 AM
Schister66's Avatar
Man U FTW
It may suck for now that you have to spend the money to have a shop properly break in and tune your setup, but in the long run, you'll be glad you didnt cut corners. If there is one thing i've learned from building turbo setups, it is that when you cut corners to cut cost, you end up spending more in the long run. Do it right the first time and forget about it
Old Feb 8, 2010 | 08:13 AM
Tony the Tiger's Avatar
The first few minutes of running is critical for a built motor....
Unless you can revert most of your fuel/ignition/cam setup back to stock and have all stock O2 sensors working, then you can slap your stock ECU back in just for break-in. If not, it needs a base tune just to get the car running properly during break-in.
Old Feb 8, 2010 | 08:58 AM
v8killaz's Avatar
pretty sure u dont want to **** up a built dart block, so pay up right now
if u wanted to play around u should have built a budget setup
Old Feb 8, 2010 | 10:34 AM
jdm inc's Avatar
x2
Old Feb 8, 2010 | 01:10 PM
SpoolnG2's Avatar
King is awesome and they really know what theyre doing when it comes to tuning. I had my car tuned there and its been running solid for 2 years now. I know its an expensive cost, but better to pay it up front and have an excellent running motor for years then not pay and break something probably very soon down the road. Just let them take care of it, I promise you wont regret it.
Old Feb 8, 2010 | 04:46 PM
d112crzy's Avatar
This.
So many people think that even running a basemap is safe. It doesn't matter if the car that basemap came from has identical parts, your motor will want something different.
Though the damage done can be somewhat corrected, just takes more time.
Old Feb 8, 2010 | 08:05 PM
2.0 and up's Avatar
You got money for a fully built dart block but no monies to tune?
Old Feb 8, 2010 | 08:52 PM
drift2004's Avatar
I got a solution for u... Fmu. And be done with it!!! It tunes it self! **** paying big bucks. That **** works by boost so u can run any amount of boost safely.
Old Feb 9, 2010 | 11:01 AM
YARO.'s Avatar
^lmfao
Old Feb 10, 2010 | 12:12 AM
cibao2ner's Avatar
im over 5k spent on my dart block alone..wats another couple hundred to tune? just get it tuned..if it was built right it doesnt need a break in like an oem motor since p2w clearances should be looser than oem..just tow ur car to king and be done with it..
beandip
Acura NSX
May 3, 2006 02:34 PM
EFin' Kyle
Dec 24, 2005 11:22 AM
4gzchatch
Jun 29, 2004 12:26 PM
