FULL RACE T4 bottom mount Twin Scroll
Old Nov 12, 2008 | 04:21 AM
XxRoCkMaNxNEOxX's Avatar
Default FULL RACE T4 bottom mount Twin Scroll
I know this manifold has been just released, but what would be the benefit of running this one compared to a topmount twinscroll? Spool time? Max HP? Size of DP...etc.?
Old Nov 12, 2008 | 04:49 AM
b00stedbyFastrax's Avatar
Default Re: FULL RACE T4 bottom mount Twin Scroll (XxRoCkMaNxNEOxX)
will be getting one soon. let you know.
Old Nov 12, 2008 | 06:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
that manifold can also facilitate a 372/42r into a crx. and still have the benefit of the twin scroll.
Old Nov 12, 2008 | 06:56 AM
TheShodan's Avatar
Moderator
Default Re: FULL RACE T4 bottom mount Twin Scroll (boostedcivicsir)
Interesting design. Like back in 99.
Old Nov 12, 2008 | 06:59 AM
Schister66's Avatar
Man U FTW
Default Re: FULL RACE T4 bottom mount Twin Scroll (TheShodan)
hahaha...ruining the fun yet again with your logic
Old Nov 12, 2008 | 09:00 AM
EARLdaSQUIRREL's Avatar
official honda whore
care to explain the comment
would one of these be better for a 30r(with twin scroll) than say the 30r with a tial housing
Old Nov 12, 2008 | 09:13 AM
extralargenog's Avatar
Default Re: FULL RACE T4 bottom mount Twin Scroll (EARLdaSQUIRREL)
Its not exactly a new design by any means... I thought the same thing, but if it works, why fix it ---
Old Nov 12, 2008 | 09:31 AM
sp00led's Avatar
I thought the 30r was only available in a T3 footprint. I know the 35r can be T3 or T4.
Old Nov 12, 2008 | 09:56 AM
Default Re: FULL RACE T4 bottom mount Twin Scroll (sp00led)
30r is only t3. you are correc t
Old Nov 12, 2008 | 11:20 AM
95dxsir2's Avatar
You have made the light come on.......next set up
Old Nov 12, 2008 | 11:35 AM
SD_Lurker's Avatar
HT White Ops
Default Re: FULL RACE T4 bottom mount Twin Scroll (95dxsir2)
Mainly for street applications and the importance of running a filter on the STREET.
Old Nov 12, 2008 | 12:03 PM
TheShodan's Avatar
Moderator
It's like what extralargenog stated, its not really a new design at all, really. that's been around for almost 10 years. The fact that it is divided housing (not "twin scroll"-see sig)) would assist with turbos of larger size, but considering our smaller displacement engines (and yes, 2.0 litres is small, get used to it), it would still have maximum pressure at higher than say 4700rpms or above depending upon the turbo used.
Old Nov 12, 2008 | 12:50 PM
can you explain the differences than? between twin scroll and divided housing, i feel this thread would be a great place for it to be explained
Old Nov 12, 2008 | 01:13 PM
downeyballz's Avatar
i also thought twin scroll and divided housing were the same thing. im gonna do some rechearch
Old Nov 12, 2008 | 01:53 PM
Default Re: FULL RACE T4 bottom mount Twin Scroll (downeyballz)
Twin scroll is NOT simply a divided housing....
It derives its name from the geometry of the exhaust gas inlet into the turbine. Two different-sized scrolls are generally used, a primary and a secondary. The primary is open for low-speed operation, and both for high-speed use. This creates the ability of the Twin scroll setup to be a small A/R housing at low speeds and a large A/R at higher speeds.
Divided is simply a split housing that you can pair runners to in order to aid spool.
Totally different
Old Nov 12, 2008 | 02:00 PM
HiProfile's Avatar
Twin scroll refers to the entire system - half the cylinders pumping into one half of the turbine. Divided refers to the housing & flange. Kinda like saying 'tranny' and 'drivetrain', one is part of the other.
The benifits of a twin-scroll setup is listed in many threads & web pages - its rather simple. Due to less volume (half in this case) for each exhaust pulse fill, you reach peak exhaust pressure faster to spool the turbo. You also prevent one exhaust pulse (opening valve) from interfering with an overlap event (closing valve), so less issues with reversion as well as better scavenging. AND since you can size the housing & runners a bit larger, you end up with better overall flow.
So you get:
*faster spool
*more power
*better scavenging
*less reversion
Its obvious why this is seen on V-motors and I-6's - its much easier to divide the cylinder pulses properly.
Old Nov 12, 2008 | 03:45 PM
Default Re: FULL RACE T4 bottom mount Twin Scroll (oldbetsy)
looks good guys. keep em coming
Old Nov 12, 2008 | 07:48 PM
leach's Avatar
geoff says there 3 to 4 weeks out but my name is on one
Old Nov 13, 2008 | 03:57 AM
Default Re: FULL RACE T4 bottom mount Twin Scroll (leach)
thats not bad let me know how it goes with your setup.
Old Mar 1, 2009 | 05:46 PM
POORMANT's Avatar
ok new to this but is there a difference between it being bottom compared to top im tryin to decide on what manifold i want and im using h1e holset turbo
Old Mar 1, 2009 | 06:14 PM
96 GSR-T's Avatar
I would imagine the bottom mount will spool the turbo faster vs the topmount mainly due to the runners being much shorter, it is probably lighter too. I wonder if it shares the same collector length/design as the topmount or if that area has been revised as well. I am very interested in this pending the price, a topmount is just too baller for me
thegatekeeper14
Dec 10, 2011 07:30 PM
tepid1
Oct 19, 2008 03:35 AM
oxSLEEPERxo
Sep 8, 2007 06:19 AM
Absentmind
Mid-Atlantic (Sales)
Jul 17, 2007 07:46 PM
sluggo
Jun 1, 2005 01:05 PM
