fuel setup for turbo civic??
Old Oct 11, 2003 | 09:10 AM
gary83335's Avatar
Default fuel setup for turbo civic??
I was wondering what the difference is between using an additional inline fuel pump to add extra gas or using a replacement in-tank fuel pump for a 2000 civic ex?? Is the intake pump better? Also I know a guy with a 2000 civic si fuel pump and thought maybe that pump would add the extra fuel needed for boosted conditions. Is that true?? I know the si eats more gas than the ex so I figured maybe it would work.
Old Oct 11, 2003 | 11:46 AM
Full-Race Henry's Avatar
Default Re: fuel setup for turbo civic?? (gary83335)
im not a big fan for inlines. i only use intank fuel pumps walbro 255 hp.
Old Oct 11, 2003 | 04:29 PM
u2civic1's Avatar
inline are usually used for fmu with stock injectors
intank are fine with upgraded injectors
Old Oct 11, 2003 | 04:32 PM
b16ahybrid's Avatar
Default Re: fuel setup for turbo civic?? (u2civic1)
depends on the rest of your set-up. either way you go intank is better then inline imo.
No the si pump will not provide more fuel then the ex pump, i believe they are the same pumps. I know my civic dx has the same pump as the teg...well at least thats the pump thats i my car (255lph holley for 95 gs-r)
Old Oct 11, 2003 | 07:58 PM
White Smoke's Avatar
i my honda
Global Mod
I am going to be running a warblo 255 with fmu for a couple days. Should I hook up my new rev-hard inline pump as well till I get my injectors? I hope not cause I want to sell the rev-hard pump new and I dont want it to seize up if I have to take off! Its just the reg 255 not the HP255.
Old Oct 12, 2003 | 03:37 PM
Default Re: fuel setup for turbo civic?? (si2die4)
should be fine for a couple of days
Old Oct 12, 2003 | 05:17 PM
FastTurboLS's Avatar
Default Re: fuel setup for turbo civic?? (EF8_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan &raquo;</TD></TR><TR><TD CLASS="quote">im not a big fan for inlines. i only use intank fuel pumps walbro 255 hp. </TD></TR></TABLE>
I used to run an inline and it worked great for awhile. Then it crapped out on me. I was chasing around tring to figure up which pump went out. I now use a intank 255 Wal with no probs so far. G/L
97grnrs
Sep 27, 2007 06:54 AM
SI_DRIVR
Jan 27, 2003 09:03 AM
DeeJay
Oct 31, 2001 09:24 PM
Teluan
Sep 4, 2001 08:56 PM
